j'ai un petit problème d’écran bleu qui me fait
whocrashed :
System Information (local)
computer name: NXS-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Pentium(R) D CPU 2.80GHz Intel586, level: 15
2 logical processors, active mask: 3
RAM: 3220758528 total
VM: 2147352576, free: 1991278592
Crash Dump Analysis
On Sat 15/12/2012 05:47:45 GMT your computer crashed
crash dump file: C:\Windows\Minidump\121512-26953-01.dmp
This was probably caused by the following module: bdselfpr.sys (bdselfpr+0xC766)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF837195FC, 0xFFFFFFFFA04B7754, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
file path: C:\Program Files\Bitdefender\Bitdefender 2012\bdselfpr.sys
product: BitDefender Firewall
company: BitDefender LLC
description: BitDefender Self Protection Driver
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: bdselfpr.sys (BitDefender Self Protection Driver, BitDefender LLC).
Google query: BitDefender LLC KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
On Sat 15/12/2012 05:35:20 GMT your computer crashed
crash dump file: C:\Windows\Minidump\121512-22718-01.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl+0x1C1FF)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF83165795, 0xFFFFFFFFAD05F7CC, 0x0)
file path: C:\Windows\system32\drivers\dxgkrnl.sys
description: DirectX Graphics Kernel
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
voila bonne journée .
ps : désolé pour les faute j'ai des problème pour écrire
