Bonjour j'ai des problèmes depuis plusieurs jours, mon pc redémarre après que je l'ai allumé parfois 3 fois de suite.
Je me suis renseignée et j'ai donc téléchargé whocrashed mais je ne comprend pas les infos qu'il me donne.
Merci d'avance pour votre aide !
Crash Dump Analysis
On Fri 19/10/2012 14:40:57 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101912-27066-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7EFC0)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80003087EA9, 0xFFFFF880029BDA60, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Fri 19/10/2012 14:38:33 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101912-27409-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF800033F626C, 0xFFFFF8800294DAB0, 0x0)
On Fri 19/10/2012 14:35:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101912-25022-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF8000307CEA9, 0xFFFFF880081A5A60, 0x0)
On Thu 18/10/2012 16:43:46 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101812-27128-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80003091EA9, 0xFFFFF88007A8CA60, 0x0)
On Wed 17/10/2012 16:51:34 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101712-27534-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF800033B226C, 0xFFFFF880036C6AB0, 0x0)
On Wed 17/10/2012 16:47:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101712-29421-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF800033C426C, 0xFFFFF880083AEAB0, 0x0)
On Sun 14/10/2012 10:54:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101412-29281-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF8000340D26C, 0x0, 0xE50D2)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
On Sat 13/10/2012 10:30:12 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101312-33696-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF800033563F0, 0xFFFFF880023FBBF0, 0x0)
On Sat 13/10/2012 10:25:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101312-29671-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80003083EA9, 0xFFFFF88007FEAA60, 0x0)
Conclusion
10 crash dumps have been found and analyzed. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
"Crash" Blue Screen
Babac
Re: "Crash" Blue Screen
Allo,
Il faut d'abord déterminer si la cause est matérielle ou logicielle.
Redémarrez en mode ''sans échec'' et si vous y arrivez sans BSOD, la cause n'est pas matérielle mais bien logicielle.
Un Blue Screen est presque toujours causé par un pilote.Il est important de tout mettre à jour
Rendez vous sur ce site et cliquez sur ''Démarrer la détection''. Acceptez l'installation d'un active x, s'il vous est proposé.
Ensuite, cliquez sur ''Mes pilotes...''et faites l'installation de tous ceux proposés.Les pilotes de vos périphériques seront alors à jour.
http://www.ma-config.com/fr
La deuxième étape consiste à mettre à jour les pilotes de vos logiciels.
Rendez vous sur ce site et installez toutes les mises à jour proposées, sauf les bétas.
http://www.commentcamarche.net/download ... updat(...)
Redémarrez l'ordi et vérifiez si vous avez toujours des Blue Screen.
Si votre problème est matériel,c'est probablement la mémoire qui serait en cause.
Faites alors un test de mémoire avec Memtest.
http://www.commentcamarche.net/faq/899- ... ec-memtest
Toutes les explications sont sur la même page.
Carte mère: Model Asus P9X79
