Crash intempestifs : IRQL_NOT_LESS_OR_EQUAL
WhiteGuts
Message par WhiteGuts »
Voilà ça fait maintenant depuis quelques jours que j'ai systématiquement ce genre de crash système. J'ai essyaé de mettre à jour mes drivers, ça n'a rien arrangé.
Rapport Who Crashed :
System Information (local)
computer name: MADRIDISTA-PC
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM)2 Duo CPU E8300 @ 2.83GHz Intel586, level: 6
2 logical processors, active mask: 3
RAM: 3219644416 total
VM: 2147352576, free: 1953058816
Crash Dump Analysis
On Tue 18/09/2012 15:00:43 GMT your computer crashed
crash dump file: C:\Windows\Minidump\091812-19187-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70040)
Bugcheck code: 0xA (0xFFFFF6FB7E8000C0, 0x2, 0x0, 0xFFFFF8000338432B)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Mon 17/09/2012 19:31:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\091712-25484-01.dmp
Bugcheck code: 0xA (0x48, 0x2, 0x1, 0xFFFFF80003333F3F)
On Mon 17/09/2012 17:59:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\091712-17953-01.dmp
Bugcheck code: 0xA (0x48, 0x2, 0x1, 0xFFFFF8000333FF3F)
On Mon 17/09/2012 15:06:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\091712-16750-01.dmp
Bugcheck code: 0xA (0x18, 0x2, 0x0, 0xFFFFF80003326FE7)
On Sun 16/09/2012 13:23:39 GMT your computer crashed
crash dump file: C:\Windows\Minidump\091612-23125-01.dmp
Bugcheck code: 0x1A (0x411, 0xFFFFF6FC5001BF48, 0xEF200000218B8882, 0xFFFFF6FC1001BF49)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Sat 15/09/2012 12:42:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\091512-19765-01.dmp
Bugcheck code: 0x1A (0x411, 0xFFFFF6FC50009AD8, 0xB4D0000048DB8882, 0xFFFFF6FC10009AD9)
On Thu 16/08/2012 01:48:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\081612-24875-01.dmp
Bugcheck code: 0x4E (0x99, 0x20C0B, 0x0, 0x4CF0B)
Error: PFN_LIST_CORRUPT
Bug check description: This indicates that the page frame number (PFN) list is corrupted.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Tue 07/08/2012 18:36:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080712-19656-01.dmp
Bugcheck code: 0x4E (0x99, 0x144FC, 0x2, 0x65782)
On Fri 27/07/2012 21:56:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\072712-19453-01.dmp
Bugcheck code: 0xA (0xFFFFF680001250A8, 0x0, 0x0, 0xFFFFF80003298B62)
On Sun 15/07/2012 09:15:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071512-25406-01.dmp
Bugcheck code: 0x4E (0x99, 0x19592, 0x1, 0x71812)
On Sun 24/06/2012 23:13:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062512-18218-01.dmp
Bugcheck code: 0xA (0xFFFFF6800015CEC0, 0x0, 0x0, 0xFFFFF800032EAB62)
Re: Crash intempestifs : IRQL_NOT_LESS_OR_EQUAL
Ces BSoD sont dus à un problème de périphérique incompatible ou non reconnu par le système.
Mais aussi parfois par une barrette mémoire défectueuse.
Avec Vista et Sept.
Dans le panneau de configuration, Outils d'administration, Diagnostic de mémoire Windows, choisis parmi les deux options proposées.
Cette opération se fera au redémarrage.
Un rapport sera affiché sur le bureau en cas de problème.
Avec Memtest, tous systèmes
Voir sur ce site
Il faut graver un CD ou l'installer sur une clé USB bootable et démarrer sur ce médium pour lancer l'analyse.
Un cycle dure environ 15 à 25 minutes avec une machine assez récente.
Image Il ne faut pas d'erreur dans le cadre en bas à droite.
loboqweq
Message par loboqweq »
I’m searching on Google “ fix IRQL_NOT_LESS_OR_EQUAL Error” and I found this link and honestly I didn’t find the answer for my solution
So I keep searching for this and I found this and reply on this forum to help other
How To Fix Stop:0x0000000A IRQL_NOT_LESS_OR_EQUAL ?
