ecran bleu
Posté : dim. 2 sept. 2012 21:51
Je viens vous demander de l'aide car je n'arrive pas à savoir pourquoi j'ai un redémarrage de mon pc avec ecran bleu.
J'ai déjà réinstaller windows 7 :
1 fois sur un autre disque dur en ide. Cela n'a rien changé.
2 fois sur le disque dur sata. Mémé erreur.
Voici l'erreur que j ai eu, je l ai recuperé avec whocrashed.
Welcome to WhoCrashed (HOME EDITION) v 3.06
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. If will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit www.resplendence.com/support
Click here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which also allows analysis of crashdumps on remote drives and computers on the network and offers a range of additional features.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
computer name: HOME
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: AuthenticAMD AMD Athlon(tm) II X2 270 Processor AMD586, level: 16
2 logical processors, active mask: 3
RAM: 8320704512 total
VM: 2147352576, free: 1972183040
Crash Dump Analysis
On Sun 02/09/2012 19:25:45 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090212-24616-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC80)
Bugcheck code: 0x19 (0x21, 0xFFFFF900C1DA5000, 0x1020, 0xA0000001020)
Error: BAD_POOL_HEADER
Bug check description: This indicates that a pool header is corrupt.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
This was probably caused by the following module: win32k.sys (win32k!XLATEOBJ_hGetColorTransform+0x5B96)
file path: C:\Windows\system32\win32k.sys
product: Système d’exploitation Microsoft® Windows®
description: Pilote Win32 multi-utilisateurs
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Sun 02/09/2012 19:20:39 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090212-24741-01.dmp
Bugcheck code: 0x19 (0x21, 0xFFFFF900C1EFD000, 0x1020, 0x80001020)
On Sun 02/09/2012 19:00:03 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090212-31184-01.dmp
Bugcheck code: 0xA (0xFFFFF6FD62000008, 0x2, 0x0, 0xFFFFF80002AE396A)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
On Sun 02/09/2012 17:07:20 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090212-15350-01.dmp
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8001D80800, 0xFFFF, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
On Sat 01/09/2012 15:25:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090112-15334-01.dmp
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8001D80860, 0xFFFF, 0x0)
On Tue 28/08/2012 05:43:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082812-17565-01.dmp
Bugcheck code: 0xD1 (0xFFFFF800D5ACB6C2, 0x2, 0x8, 0xFFFFF800D5ACB6C2)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
On Mon 27/08/2012 02:51:44 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082712-15724-01.dmp
On Sun 26/08/2012 18:44:18 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082612-16270-01.dmp
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8001C36890, 0xFFFF, 0x0)
On Sun 26/08/2012 04:09:16 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082612-23977-01.dmp
Bugcheck code: 0x50 (0xFFFFF9805B212938, 0x0, 0xFFFFF88001217460, 0x5)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
On Sun 26/08/2012 04:02:34 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082612-23899-01.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0xC6CBC)
Bugcheck code: 0x34 (0x50853, 0xFFFFF88002FBE4A8, 0xFFFFF88002FBDD00, 0xFFFFF880012FFCBC)
Error: CACHE_MANAGER
file path: C:\Windows\system32\drivers\ntfs.sys
description: Pilote du système de fichiers NT
Bug check description: This indicates that a problem occurred in the file system's cache manager.
On Sun 26/08/2012 03:58:17 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082612-19422-01.dmp
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8001C36800, 0xFFFF, 0x0)
On Fri 24/08/2012 19:29:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082412-15506-01.dmp
Bugcheck code: 0x50 (0xFFFFF8A00A471128, 0x0, 0xFFFFF80002F21CE1, 0x0)
On Wed 22/08/2012 10:59:11 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082212-14648-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002BFE9BC, 0xFFFFF88006C32FC0, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
On Wed 22/08/2012 10:15:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082212-15350-01.dmp
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8001D80890, 0xFFFF, 0x0)
Conclusion
30 crash dumps have been found and analyzed. Only 15 are included in this report. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
D'avance merci pour votre aide
Home Edition Notice
computer name: HOME
Crash Dump Analysis
Conclusion
