Problème écran bleu
Posté : dim. 10 juin 2012 10:06
par tintinak
Bonjour depuis quelque temps, j'ai un problème de reboot "écran bleu" plusieurs fois par jour.
Je me suis rendu compte que lorsque je lance plusieurs logiciels en même temps l'ordinateur plante.
Je viens de faire un "whocrashed" et voici la réponse/
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 4202221568 total
VM: 2147352576, free: 1944367104
Crash Dump Analysis
On Sun 10/06/2012 07:53:16 GMT your computer crashed
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0x1A (0x41287, 0x30, 0x0, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Sat 09/06/2012 18:23:11 GMT your computer crashed
crash dump file: C:\Windows\Minidump\060912-14882-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x71F00)
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8000667680, 0xFFFF, 0x0)
On Sun 03/06/2012 12:54:31 GMT your computer crashed
crash dump file: C:\Windows\Minidump\060312-13478-01.dmp
Bugcheck code: 0x1A (0x41790, 0xFFFFFA80006676B0, 0xFFFF, 0x0)
On Wed 23/05/2012 06:06:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052312-14898-01.dmp
On Tue 22/05/2012 19:49:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052212-26426-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002DAC0BF, 0xFFFFF88009147E60, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
Pensez vous que mes barrettes soient défectueuses?
Merci pour votre aide.
Re: Problème écran bleu
Posté : dim. 10 juin 2012 11:23
par Alain Quarré
Avant le passage d'un helper, fais ceci.
Touche Windows + R, tape MSCONFIG ==> Enter
Dans l'onglet services, coche: Masquer tout les services Microsoft
puis clic sur Désactiver tout
Ensuite dans la liste, retrouve ton antivirus et coche le pour qu'il démarre.
Dans l'onglet Démarrage.
clic sur Désactiver tout, puis retrouve aussi ton antivirus pour le sélectionner.
Redémarre ton PC.
après cela, tu pourras réactiver ce qui t'es indispensable. (tu constateras qu'il n'y a pas grand chose d'indispensable au fonctionnement de ton PC)
en option, va dans programme et fonctionnalité et désinstalle tout ce que tu trouveras comme Toolbar, sauf celle que tu utilises (personne n'utilise de toolbar)
Cela fait, l'aide d'un Helper du forum te guidera pour une recherche plus approfondie de problème sur ton PC.
Alain
Posté : dim. 10 juin 2012 18:13
par tintinak
Merci je test et je vous dis ce qu'il en est.
Posté : lun. 11 juin 2012 14:57
L'erreur 1A est liée soit à :
-Un matériel nouvellement installé qui serait incompatible
-Une barrette mémoire défectueuse.
Tu débranches tous les périphériques autre que clavier, souris et écran.
Si le problème persiste, teste la mémoire.
Avec Vista et Sept.
Dans le panneau de configuration, Outils d'administration, Diagnostic de mémoire Windows, choisis parmi les deux options proposées.
Cette opération se fera au redémarrage.
Un rapport sera affiché sur le bureau en cas de problème.
Avec Memtest, tous systèmes
Voir sur ce site
Il faut graver un CD ou l'installer sur une clé USB bootable et démarrer sur ce médium pour lancer l'analyse.
Un cycle dure environ 15 à 25 minutes avec une machine assez récente.
Image Il ne faut pas d'erreur dans le cadre en bas à droite.
