Problème de mise en veille prolongée + extinction du PC
rousselziak
Message par rousselziak »
j' ai 2 problemes sur mon os ( seven 64 ) , voila : 1er : quand mon pc se met en veille prolongée, il me fait souvent un ecran bleu et redémarre nickel en mode normal, le 2eme, c'est qu'il a souvent du mal à s'éteindre et je suis obligé de faire un reset pour l'eteindre !
J'ai telechargé " whocrashed " et je vous poste le rappord :
computer name: SALON
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: AuthenticAMD AMD Phenom(tm) II X6 1090T Processor AMD586, level: 16
6 logical processors, active mask: 63
RAM: 8586301440 total
VM: 2147352576, free: 1940045824
Crash Dump Analysis
On Fri 26/08/2011 14:04:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082611-25974-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7F4DA)
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006E2AB60, 0xFFFFF80000B9C510)
Error: CUSTOM_ERROR
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0x9F (0x4, 0x258, 0xFFFFFA8006E2AB60, 0xFFFFF80000B9C510)
Error: DRIVER_POWER_STATE_FAILURE
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
On Fri 26/08/2011 12:30:47 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082611-26176-01.dmp
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006E2CB60, 0xFFFFF80000B9C510)
Error: CUSTOM_ERROR
On Fri 26/08/2011 10:43:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082611-27112-01.dmp
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006DC8040, 0xFFFFF80000B9C510)
Error: CUSTOM_ERROR
On Mon 22/08/2011 10:50:12 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082211-25896-01.dmp
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006DDD040, 0xFFFFF80000B9C510)
Error: CUSTOM_ERROR
On Thu 21/07/2011 16:59:07 GMT your computer crashed
crash dump file: C:\Windows\Minidump\072111-35755-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x824DA)
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006E00040, 0xFFFFF80000B9C510)
Error: CUSTOM_ERROR
On Sat 16/07/2011 19:34:39 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071611-25521-01.dmp
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006DF6040, 0xFFFFF80000B9C510)
Error: CUSTOM_ERROR
On Sat 16/07/2011 13:58:29 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071611-25724-01.dmp
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006DB2040, 0xFFFFF8000473C510)
Error: CUSTOM_ERROR
On Thu 07/07/2011 20:55:47 GMT your computer crashed
crash dump file: C:\Windows\Minidump\070711-23478-01.dmp
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006E0EB60, 0xFFFFF80000B9C510)
Error: CUSTOM_ERROR
On Sun 26/06/2011 12:33:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062611-25755-01.dmp
Error: CUSTOM_ERROR
On Wed 22/06/2011 19:34:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062211-25927-01.dmp
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA800B1D4640, 0xFFFFF8000473C510)
Error: CUSTOM_ERROR
On Mon 13/06/2011 10:19:15 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061311-25740-01.dmp
Error: CUSTOM_ERROR
On Sun 12/06/2011 12:45:46 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061211-25459-01.dmp
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006DE4040, 0xFFFFF80000B9C510)
Error: CUSTOM_ERROR
On Sun 22/05/2011 12:46:26 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052211-25646-01.dmp
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006E2AB60, 0xFFFFF8000473C510)
Error: CUSTOM_ERROR
On Fri 20/05/2011 22:28:06 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052111-26317-01.dmp
Bugcheck code: 0x1000009F (0x4, 0x258, 0xFFFFFA8006D57B60, 0xFFFFF80000B9C510)
Error: CUSTOM_ERROR
HELP
Re: Problème de mise en veille prolongée + extinction du PC
Bonjour rousselziak
juste vu ceci pour info :arrow: http://support.microsoft.com/kb/2459268/fr et peut-être vérifier tes pilotes dans le gestionnaire de périphériques
il aurait aussi fallu connaitre la marque ,la série du pc et windows quoi 64 bits pour des recherches chez le constructeur .
peut-être vérifier les barrettes mémoires ou un problème de compatibilité avec un programme installé sur ton pc .
Modifié en dernier par grimpeur le sam. 27 août 2011 14:03, modifié 5 fois.
Jango78
Message par Jango78 »
Un premier élément... le code 0x1000009F n'est pas officiellement référencé, donc erreur générique custom_error, ce qui n'est pas mieux que "erreur inconnue".
Cependant il est parfois associé à DRIVER_POWER_STATE_FAILURE.
Donc un classique problème matériel impliquant éventuellement un ou plusieurs composants et/ou des pilotes.
Par ailleurs, selon la situation, il peut-être demandé de faire une analyse avec l'outil ZHPDiag de Nicolas Coolman à télécharger sur le Bureau.
Un tuto ICI.
Autrement tester un fix Microsoft s'il existe, vérifier les composants (USB, barrettes de RAM et autres), ou tenter une restauration du système à une date antérieure, ou réinstaller Seven, etc...
EDIT 27/08 12:45: il manque deux précisions qui peuvent être d'importance:
- l'ordi en question est-il de marque (HP, Acer ou autre) et si oui, merci d'indiquer le nom du fabricant + série/modèle.
- des logiciels et outils de nettoyage ont-ils été installés et utilisés, par ex. suite de sécurité antivirus + firewall ou autre, CCleaner, Glary ou équivalent :?:
Message par SYNTAX-ERROR »
Si tu as le DVD de Win7 (version boite) sert toi de l'option réparer.
Tu peux créer le CD de réparation si tu n'as pas le DVD original Microsoft.
Tu peux aussi lancer L'invite de commande en tant qu'administrateur et saisir sfc /scannow pour vérifier et réparer les fichiers.(espace entre sfc et scannow)
Tu tapes cmd dans la zone rechercher du menu démarrer et tu l'ouvres en faisant clic droit dessus =>exécuter en tant qu'administrateur
Mais le problème ntoskrnl.exe est une vraie galère a résoudre.
