Aide pour comprendre un BlueScreen
Posté : sam. 9 avr. 2011 21:50
Bonsoir à tous,
Sur un forum on m'a dit d'utiliser le programme Whocrashed pour analyser les deux écrans bleus que j'ai eu dernièrement.
Je vous poste les résultats
"Crash Dump Analysis
On Fri 08/04/2011 18:43:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\040811-15880-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70740)
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF800032C0E3B)
Error: UNEXPECTED_KERNEL_MODE_TRAP
Bug check description: This bug check indicates that the Intel CPU generated a trap and the kernel failed to catch this trap.
This was probably caused by the following module: mfewfpk.sys (mfewfpk+0x7883)
file path: C:\Windows\system32\drivers\mfewfpk.sys
product: SYSCORE
company: McAfee, Inc.
description: Anti-Virus Mini-Firewall Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: mfewfpk.sys (Anti-Virus Mini-Firewall Driver, McAfee, Inc.).
Google query: mfewfpk.sys McAfee, Inc. UNEXPECTED_KERNEL_MODE_TRAP
On Tue 29/03/2011 19:50:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032911-13837-01.dmp
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF800032D605F)
Conclusion
3 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems."
Merci de votre aide
product: SYSCORE
Conclusion
Merci de votre aide
