Code erreur 0xc0000005 sur Windows 7 32bits
desperado_mig
Re: Code erreur 0xc0000005 sur Windows 7 32bits
Message par desperado_mig »
Voici le rapport avec le findstr /C:"[SR] Cannot repair"
2010-05-21 13:38:37, Info CSI 000000d1 [SR] Cannot repair member file [l:24{12}]"MP4SDECD.DLL" of Microsoft-Windows-MP4SDECD, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-21 13:38:38, Info CSI 000000dc [SR] Cannot repair member file [l:24{12}]"MP4SDECD.DLL" of Microsoft-Windows-MP4SDECD, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-21 13:40:52, Info CSI 0000015e [SR] Cannot repair member file [l:22{11}]"msvcr90.dll" of Microsoft.VC90.CRT, Version = 9.0.30729.4926, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope neutral, PublicKeyToken = {l:8 b:1fc8b3b9a1e18e3b}, Type = [l:10{5}]"win32", TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-21 13:40:53, Info CSI 00000160 [SR] Cannot repair member file [l:22{11}]"msvcr90.dll" of Microsoft.VC90.CRT, Version = 9.0.30729.4926, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope neutral, PublicKeyToken = {l:8 b:1fc8b3b9a1e18e3b}, Type = [l:10{5}]"win32", TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-21 13:41:36, Info CSI 0000019f [SR] Cannot repair member file [l:24{12}]"MP4SDECD.DLL" of Microsoft-Windows-MP4SDECD, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-21 13:41:36, Info CSI 000001a1 [SR] Cannot repair member file [l:22{11}]"msvcr90.dll" of Microsoft.VC90.CRT, Version = 9.0.30729.4926, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope neutral, PublicKeyToken = {l:8 b:1fc8b3b9a1e18e3b}, Type = [l:10{5}]"win32", TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-21 13:41:36, Info CSI 000001a3 [SR] Cannot repair member file [l:24{12}]"MP4SDECD.DLL" of Microsoft-Windows-MP4SDECD, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-05-21 13:41:36, Info CSI 000001a9 [SR] Cannot repair member file [l:22{11}]"msvcr90.dll" of Microsoft.VC90.CRT, Version = 9.0.30729.4926, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope neutral, PublicKeyToken = {l:8 b:1fc8b3b9a1e18e3b}, Type = [l:10{5}]"win32", TypeName neutral, PublicKey neutral in the store, hash mismatch
Ce n'est pas très lisible mais ça incrimine bien les 2 dll indiquées précédemment MP4SDECD.DLL et msvcr90.dll.
Que faire ? télécharger ces 2 DLL sur le net, réinstaller, réparer ?
Merci de votre aide
desperado_mig
Mon fichier mp4sdecd.dll dans C:\Windows\System32 fait 406 Ko et c'est celui d'origine 6.1.7600.16385 du 14/07/2009
Tu peux vérifier le tien ?
Je ne peux pas vérifier la date et la version pour le moment, je ne suis pas sur le poste incriminé (j'ai recopié le fichier CBS.log), je vais regarder ça ce soir.
Par contre, le N° du fichier d'origine semble bon : \SystemRoot\WinSxS\x86_microsoft-windows-mp4sdecd_31bf3856ad364e35_6.1.7600.16385_none_0ebebeb7ce7cc727\MP4SDECD.DLL do not match actual file [l:24{12}]"MP4SDECD.DLL" :
On peut tenter de réparer.
Je vais essayer de te préparer des fichiers en téléchargement de mon système qui lui n'a aucun problème.
desperado_mig
Merci Chantal,
je suis effectivement preneur de tes DLL propres.
Je vais tester ça ce WE.
Mais je me demande quand même si ces problèmes de DLL sont liés à ce code erreur 0xc0000005.
Donc voici pour télécharger un dossier zippé qui contient les 2 dll
http://www.megaupload.com/?d=8HBEN46F
Pour MP4SDECD.DLL il est dans C:\Windows\System32
Il te faut renommer ton propre fichier en MP4SDECD-old.DLL
Puis tu copies-colles celui que tu as téléchargé dans C:\Windows\System32
Pour msvcr90.dll, celui qui est corrompu est dans C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcbc0e5a
Attention, il y a plusieurs dll msvcr sous C:\Windows
Tu renommes ton propre fichier en msvcr90-old.dll
Puis tu copies-colles celui que tu as téléchargé dans C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcbc0e5a
Il te faudra certainement prendre possession des fichiers dll avant de les manipuler par cette procédure :
Se rendre propriétaire d’un fichier Système sous Vista et Seven
Crée un point de restauration manuel avant toute manipulation.
desperado_mig
Merci,
je vais tester ça ce soir ou ce WE et je te tiens au courant.
Quelle réactivité, je suis impressionné !!
Si cela ne fonctionne pas, tu seras bon pour une réparation de Windows 7 par cette procédure :
Installation de Windows 7 en mise à niveau sans perte de données et logiciels
desperado_mig
Bonjour Chantal,
Merci pour tes DLL, j'ai pu réinstaller la première (MP4SDECD.DLL) sans problème avec ta méthode de prise de possession. Par contre, pour la 2eme, pas moyen de le faire...
J'ai essayé d'autres choses :
- flash du bios,
- chkdisk,
- anti virus Microsoft Security Essential (qui m'a d'ailleurs trouvé un trojan),
- désinstallation puis réinstallation de shark007 Win 7 codec pour WMP (qui m'a résolu mon problème avec Ffdshow et sans doute mp4sdecd.dll).
J'ai toujours mon problème 0xc0000005 sur openoffice (que j'ai supprimé et remplacé par une vieille version d'office XP qui trainait mais qui marche toujours).
Mon problème avec l'explorateur qui redémarre semble avoir disparu mais je ne vais pas crier victoire trop vite, on verra à l'usage...
Je me demande cependant si l'explorateur ne perd pas les pédales quand j'ai un dvd dans le lecteur (chose qui m'arrive assez peu).
Donc pour le moment, ça va, sauf que je ne peux pas installer tous les logiciels que je veux à cause de cette erreur.
Question concernant l'installation de Win 7 en mise à niveau sans perte de programmes et de données : je voudrai bien être sûr qu'il n'y aura pas à réinstaller tous les programmes :
J'ai une partition C: avec Windows, les drivers et les logiciels liés aux matériels (Nvidia...), j'ai un D: avec les programmes Tiers, un E: avec les jeux, un D: avec les docs administratifs, un E: avec mes photos, divx et mp3 et un F: pour le swap (pagefile windows).
Tous les programmes et les jeux seront-ils opérationnels après la mise à niveau ?
desperado_mig a écrit :Tous les programmes et les jeux seront-ils opérationnels après la mise à niveau ?
Il n'y a pas de raison que ces programmes et jeux ne soient plus fonctionnels après la mise à niveau.
desperado_mig a écrit :Donc pour le moment, ça va, sauf que je ne peux pas installer tous les logiciels que je veux à cause de cette erreur.
Je ne sais plus si je te l'ai déjà demandé, mais as-tu essayé sous une toute nouvelle session administrateur que tu crées spécifiquement pour le test ?
desperado_mig
Effectivement, je n'ai pas testé avec un nouveau profil admin. Je vais essayer ça à l'occasion (avant ce WE j'espère...).
Et si le problème avec l'explorateur windows continue, je tenterai la mise à niveau.
