pc qui redemar suite a un ecran bleu stop 0x000000a(.........)
thib
Message par thib »
bonjour ,
voici mon problème , j utilise mon pc et celui ci m affiche un écran bleu avec un message IRQL_NOT_LESS_OR_EQUAL et une série de chiffre
0x0000000a (0xfffffa7ffffcffeo. ............) . un peut n importe quand , des fois juste après l avoir allumer des fois une heures après c est vraiment aléatoire.
j ai vu sur le forum que vous conseillez d utiliser whocrashed et de publier son rapport ici,
System Information (local)
computer name: THIBMARIE-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
Hardware: Gigabyte Technology Co., Ltd., 990FXA-UD3
CPU: AuthenticAMD AMD FX(tm)-4300 Quad-Core Processor AMD586, level: 21
4 logical processors, active mask: 15
RAM: 6405386240 total
Crash Dump Analysis
On Sun 19/10/2014 12:16:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101914-20467-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75BC0)
Bugcheck code: 0x1E (0xFFFFFFFFC000001D, 0xFFFFF800034758C6, 0x0, 0xFFFFFA800589CB00)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Sat 18/10/2014 19:03:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101814-22542-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC000001D, 0xFFFFF800034768C6, 0x0, 0xFFFFFA8005500B00)
On Sat 18/10/2014 17:09:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101814-24866-01.dmp
Bugcheck code: 0xA (0xFFFFFA8011797B9F, 0x2, 0x0, 0xFFFFF800032CA2F7)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
On Thu 16/10/2014 21:49:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101614-20373-01.dmp
Bugcheck code: 0xA (0xFFFFFA7FFFFCFFE0, 0x2, 0x1, 0xFFFFF80003291AC1)
On Thu 16/10/2014 19:09:33 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101614-19936-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC000001D, 0xFFFFF800034D48C6, 0x0, 0xFFFFFA8005A52100)
On Sun 05/10/2014 13:42:40 GMT your computer crashed
crash dump file: C:\Windows\Minidump\100514-22994-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC000001D, 0xFFFFF800034B88C6, 0x0, 0xFFFFFA8007496B00)
On Wed 24/09/2014 16:20:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092414-18844-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC000001D, 0xFFFFF800034888C6, 0x0, 0xFFFFFA8009271B00)
On Sun 21/09/2014 19:58:16 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092114-37159-01.dmp
Bugcheck code: 0x1A (0x41287, 0x41177423, 0x0, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Sat 20/09/2014 18:19:07 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092014-26660-01.dmp
Bugcheck code: 0x50 (0xFFFFF7FFF357C492, 0x8, 0xFFFFF7FFF357C492, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
Conclusion
20 crash dumps have been found and analyzed. Only 10 are included in this report. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
je remercie d avance la ou les personnes qui consacreront un peut de leurs temps libres a essayer de maider .
alain 64
Re: pc qui redemar suite a un ecran bleu stop 0x000000a(.........)
Message par alain 64 »
Est ce que tous tes pilotes sont à jour ?
J'ai bien l'impression que tes barrettes mémoires peuvent être aussi en cause :hein:
Tu peux faire le test de ta mémoire RAM avec windows 7:
Tester sa mémoire RAM avec Windows 7
A plus :coucou:
thib
Message par thib »
Salut Alain 64,
Merci pour ta reponse :super:
Pour la mise à jour des pilotes en théorie oui il sont tous à jours. A moins que je ne m y prenne comme un manche. :hein:
J ai lu sur le forum ou autres par que ça pourrait être du à cause d un pilote de nvidia j ai contrôler. Et le pilote installer pour ma carte graphique n est pas celui concerner.
Pour les ram j ai lancer un test et il me dis que tout est ok. J ai vu sur le forum qu il y avait un test mémoire à télécharger et à graver sur un cd puis l exécuter es que j essaye avec celui la ?
J ai aussi lu je ne sais plus ou que ça pourrait venir d un virus , avast ne détecte rien mais es qu il est fiable ce avast ?
loboqweq
Message par loboqweq »
I had a recurring STOP 0x0000000A and traced it to a bad USB hub drivers :ugeek:
http://www.deskdecode.com/how-to-fix-st ... an_-equal/
