Ne modifie pas le contenu des rapports, s'il te plaît.
Je ne peux pas établir de script valide si tu modifies des informations.
   ZHPFix :- Copie toutes les lignes ci-dessous (Tout sélectionner -> Clic-droit -> Copier)
Code : Tout sélectionner
SysRestore R3 - URLSearchHook: (no name) [64Bits] - {81017EA9-9AA8-4A6A-9734-7AF40E7D593F} . (.Microsoft Corporation - Office Authorization plug-in for NPAPI browsers.) (No version) -- (.not file.) O2 - BHO: (no name) [64Bits] - {1658D3A1-9E13-4196-A82A-D70D70880F36} Clé orpheline O2 - BHO: (no name) [64Bits] - {E76FD755-C1BA-4DCB-9F13-99BD91223ADE} Clé orpheline O43 - CFD: 24/09/2012 - 12:21:26 - [0] ----D C:\Users\DoPi\AppData\Local\DrmRemoval O43 - CFD: 28/11/2012 - 11:00:23 - [116,820] ----D C:\Program Files (x86)\DrmRemoval [MD5.31F3CF74759BE9196408EEBFE9E93626] [SPRF][27/11/2012] (...) -- C:\Users\DoPi\Desktop\SecurityCheck.exe [856731] [MD5.00000000000000000000000000000000] [APT] [{19EAD52B-66CD-48A1-9CB6-000DC28DC66D}] (...) -- C:\Users\DoPi\Downloads\antidote 6 + le dictionnaire visuel +keygen\Antidote.2004.Prisme.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{44A9C987-FB34-42A2-872F-67BA4B0B7D7C}] (...) -- C:\Users\DoPi\Downloads\antidote 6 + le dictionnaire visuel +keygen\Antidote.2004.Prisme.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{48C304F4-3C8D-4F81-8241-3FC51AE8DFAF}] (...) -- G:\POUR W7 HP\CutOut3_FRA2\CutOut3x64Setup_Fr.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{491D656E-5CE9-45DD-8A34-2D0BC570098E}] (...) -- C:\Users\DoPi\Downloads\ToolBarSD.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{7D536F1F-DBDA-4A2E-804B-223B30D5FE2A}] (...) -- G:\POUR W7 HP\CutOut3_FRA2\CutOut3x64Setup_Fr.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{7E105F67-3333-4ED6-8C95-5D7CFD304EE2}] (...) -- G:\POUR W7 HP\CutOut3_FRA2\CutOut3Setup_Fr.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{8412DEA1-872D-4F08-9155-E321494A1E4C}] (...) -- C:\Users\DoPi\Downloads\antidote 6 + le dictionnaire visuel +keygen\Antidote.2004.Prisme.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{997B8CE9-6492-4E96-B3DA-DAF397807E3F}] (...) -- G:\POUR W7 HP\CutOut3_FRA2\CutOut3Setup_Fr.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{A26D8FA6-9031-4355-A848-51CBBDECF6B1}] (...) -- C:\Users\DoPi\Downloads\antidote 6 + le dictionnaire visuel +keygen\Antidote.2004.Prisme.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{C5A8076F-14CB-4F6A-B9F2-CDFB2E142D46}] (...) -- C:\Users\DoPi\Downloads\antidote 6 + le dictionnaire visuel +keygen\Antidote.2004.Prisme.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{DA0A851B-F7B1-4426-A1CF-2FD4ECFB5AA3}] (...) -- C:\Users\DoPi\Downloads\antidote 6 + le dictionnaire visuel +keygen\Antidote.2004.Prisme.exe (.not file.) [MD5.00000000000000000000000000000000] [APT] [{ED0FC3C6-C211-4B57-956D-A24A6A6D82CE}] (...) -- C:\Users\DoPi\Downloads\ToolBarSD.exe (.not file.) [HKLM\Software\Classes\Interface\{431532BD-0AE1-4ABC-BE8C-919F3D1332E2}] [HKLM\Software\Classes\AppID\{D616A4A2-7B38-4DBC-9093-6FE7A4A21B17}] [HKLM\Software\Wow6432Node\Classes\AppID\{D616A4A2-7B38-4DBC-9093-6FE7A4A21B17}] [HKLM\Software\Classes\AppID\{608D3067-77E8-463D-9084-908966806826}] [HKLM\Software\Wow6432Node\Classes\AppID\{608D3067-77E8-463D-9084-908966806826}] [HKLM\Software\Classes\AppID\{EA28B360-05E0-4F93-8150-02891F1D8D3C}] [HKLM\Software\Wow6432Node\Classes\AppID\{EA28B360-05E0-4F93-8150-02891F1D8D3C}] [HKLM\Software\Wow6432Node\DrmRemoval] [HKCU\Software\DrmRemoval] EMPTYTEMP EmptyFlash EMPTYCLSID FirewallRaz - Ferme toutes les applications ouvertes
 - Double-clique sur ZHPFix, raccourci sur ton Bureau
/!\ Sous Vista et Windows 7, il faut lancer le fichier par clic-droit -> Exécuter en tant qu'administrateur - Clique sur H
Les lignes copiées apparaissent directement dans le cadre blanc (si ce n'est pas le cas clic-droit -> Coller) - Clique sur GO
 - Valide par Oui la désinstallation des programmes si demandé, mais refuse le redémarrage du PC, si proposé à ce moment là (cela stopperait l'action du fix)
 - Laisse l'outil travailler. Si un redémarrage est demandé, cette fois-ci tu valides et tu redémarres le PC
 - Le rapport s'affiche. Poste le rapport ZHPFixReport.txt, enregistré sur ton Bureau, dans ta prochaine réponse.
  SX Check&Update :- Télécharge SX Check&Update de igor51 et enregistre-le sur ton Bureau
 - Double-clique sur SXC&U.exe pour lancer l'application
/!\ Sous Vista et Windows 7, il faut lancer le fichier par clic-droit -> Exécuter en tant qu'administrateur - Au menu principal, clique sur le bouton Rapport
 - Copie-colle le contenu de ce rapport dans ta prochaine réponse.
Sont attendus les rapports :
- ZHPFixReport.txt
 - SX Check&Update
 pour ton aide et ta patience
 Chantal,
 tes conseils et la découverte de
