porte document
toubib
Re: porte document
Message par toubib »
voila le résultat :
la vérification 55% est terminée
la protection des ressources windows a trouvé des fichiers endommagés, mais n'a pas réussi à tous les réparer. Des détails sont inclus dans le journal CBS.log windir\logs\CBS\CBS.log. Par exemple C:\windows\Logs\CBS\CBS.Log
toubib
Re: porte document
voci la fin du contenu du fichier
2012-05-11 07:25:44, Info CSI 00000bbf Repair results created:
POQ 49 starts:
0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\db923383362fcd01b81900008408c80d._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\ebb93383362fcd01b91900008408c80d.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\17343b83362fcd01ba1900008408c80d.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
3: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\19ef3f83362fcd01bb1900008408c80d.$$_system32_logfiles_firewall_488be49cc4415d55.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_system32_logfiles_firewall_488be49cc4415d55.cdf-ms"
POQ 49 ends.
2012-05-11 07:25:44, Info CSI 00000bc0 [SR] Verify complete
2012-05-11 07:25:44, Info CSI 00000bc1 [SR] Verifying 100 (0x0000000000000064) components
2012-05-11 07:25:44, Info CSI 00000bc2 [SR] Beginning Verify and Repair transaction
2012-05-11 07:25:52, Error CSI 00000bc3 (F) STATUS_OBJECT_NAME_NOT_FOUND #2865493# from Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysCreateFile(flags = (AllowSharingViolation), handle = {provider=NULL, handle=0}, da = (SYNCHRONIZE|FILE_READ_ATTRIBUTES), oa = @0x10dcbf0->OBJECT_ATTRIBUTES {s:48; rd:NULL; on:[100]"\??\C:\Windows\WinSxS\amd64_prnge001.inf_31bf3856ad364e35_6.1.7600.16385_none_370faef49da5c275\Amd64"; a:(OBJ_CASE_INSENSITIVE)}, iosb = @0x10dcbd0, as = (null), fa = 0, sa = (FILE_SHARE_READ|FILE_SHARE_WRITE|FILE_SHARE_DELETE), cd = FILE_OPEN, co = (FILE_SYNCHRONOUS_IO_NONALERT|0x00004000), eab = NULL, eal = 0, disp = Invalid)
[gle=0xd0000034]
2012-05-11 07:25:52, Error CSI 00000bc4@2012/5/11:05:25:52.936 (F) d:\win7sp1_gdr\base\wcp\sil\merged\ntu\ntsystem.cpp(2057): Error STATUS_OBJECT_NAME_NOT_FOUND originated in function Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysCreateFile expression: (null)
[gle=0x80004005]
2012-05-11 07:25:52, Info CBS Failed to submit the Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2012-05-11 07:25:52, Error CSI 00000bc5 (F) STATUS_OBJECT_NAME_NOT_FOUND #2865492# from Windows::Rtl::SystemImplementation::CDirectory::OpenExistingDirectory(...)[gle=0xd0000034]
2012-05-11 07:25:52, Error CSI 00000bc6 (F) STATUS_OBJECT_NAME_NOT_FOUND #2865491# from Windows::Rtl::SystemImplementation::CDirectory_IRtlDirectoryTearoff::OpenExistingDirectory(flags = 0, da = (SYNCHRONIZE), oa = @0x10dd500->SIL_OBJECT_ATTRIBUTES {s:40; on:"Amd64"; a:(OBJ_CASE_INSENSITIVE)}, sa = (FILE_SHARE_READ|FILE_SHARE_WRITE), oo = (FILE_DIRECTORY_FILE|FILE_SYNCHRONOUS_IO_NONALERT|FILE_OPEN_FOR_BACKUP_INTENT), dir = NULL, disp = (null))
[gle=0xd0000034]
Re: porte document
Je préfère avoir le log des fichiers non réparés.
Démarrer -> Tous les Programmes -> Accessoires -> clic-droit sur Invite de commandes -> Exécuter en tant qu'administrateur
Tu copies-colles et valides par Entrée :
b]findstr /C:"[SR] Cannot repair" %windir%\logs\cbs\cbs.log >sfcdetails2.txt[/b]
Tu déploies ensuite dans l'explorateur
C:\Windows\System32
et tu recherches le fichier sfcdetails2.txt
Tu fais un copier-coller du contenu de ce fichier dans ta réponse.
toubib
Re: porte document
c'est fait j'ai le document texte ais je ne peux joindre car trop gros. pouvez vous me donner votre mail par mp pour que j'envoi le texte par ce biais ?
toubib
Re: porte document
toubib
Re: porte document
voici telechargeable via ce lien...
Re: porte document
Je n'ai pas tout détaillé, mais tu as quand même une multitude de fichiers système qui ne peuvent pas être réparés.
Ton Windows 7 est mal en point.
Tu aurais tout intérêt à tenter une réparation par mise à niveau, si tant est que tu possèdes le DVD d'installation de Windows 7.
Attention, dans la mesure où tu es sans doute sous SP1; il te faut le DVD avec le SP1 inclus.
Installer / Réparer Windows 7 en mise à niveau sans perte de données et logiciels
toubib
Re: porte document
malheur à moi... j'ai bien le dvd mais impossible de procéder à la mise a niveau. je reçoit le message suivant : impossible d'effectuer une mise a niveau d'une version 64 bit vers une version 32 bits alors que je choisis bien la version 64 bits... tu penses qu'un formatage s'impose??
ou bien est-ce mon dvd d'installation qui serait merdouillant?
Re: porte document
toubib a écrit :impossible d'effectuer une mise a niveau d'une version 64 bit vers une version 32 bits alors que je choisis bien la version 64 bits... tu penses qu'un formatage s'impose??
Ton Windows 7 installé est bien en 64 bits ?
Il te faut dans ce cas, utiliser le DVD 64 bits.
toubib
Re: porte document
oui ma version installée est bien la 64 bits et sur le dvd j'ai le choix depuis starter jusqu'a integrale et X86 ou X64 et j'ai bien opté pour la version X64. Je me dit que peut etre le fait d'avoir un dvd ancien par rapport à l'installation ayant ete mise a jour en permanence en ligne ne me permet pas cette mise a niveau... pourtant j'opte pour l'installation avec connexion internet pour la toute derniere MAJ...
comprend pas...
