Bluescreen
Tene
Bluescreen
Message par Tene »
J'ai formater Hier aprem et depuis j'enchaine les Bluescreen, mais que en jouant en League of Legend et qu'en fin de partie...
On Thu 29/03/2012 15:01:08 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032912-22417-01.dmp
This was probably caused by the following module: dxgmms1.sys (dxgmms1+0x1D6BC)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF9213C6BC, 0xFFFFFFFFAACC3968, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\drivers\dxgmms1.sys
description: DirectX Graphics MMS
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
This was probably caused by the following module: dxgmms1.sys (dxgmms1+0x1DF53)
Bugcheck code: 0x8E (0xFFFFFFFFC0000005, 0xFFFFFFFF9213C6BC, 0xFFFFFFFFAACC3968, 0x0)
Bug check description: This bug check indicates that a kernel-mode application generated an exception that the error handler did not catch.
On Wed 28/03/2012 12:16:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032812-16021-01.dmp
This was probably caused by the following module: klif.sys (klif+0x20019)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF9213C6BC, 0xFFFFFFFFB153F9C4, 0x0)
file path: C:\Windows\system32\drivers\klif.sys
product: Kaspersky™ Anti-Virus ®
company: Kaspersky Lab
description: Klif Mini-Filter [fre_wlh_x86]
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: klif.sys (Klif Mini-Filter [fre_wlh_x86], Kaspersky Lab).
Google query: klif.sys Kaspersky Lab KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
3 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
Re: Bluescreen
Kaspersky est en cause une fois sur les trois.
Mais cela peut venir plus vraisemblablement d'une barrette mémoire.
Fais un test.
Tene
Re: Bluescreen
Message par Tene »
Faire des test comment ? en enlevant une barrette de ram puis l'autre voir si tout marche mieux qu'avec une seule savoir si une des deux n'as pas grillé ?
J'ai lu que les deux premiers était a cause de Direct X et l'autre a cause de Kaspersky, plusieurs personnes ont eu les mêmes bluescreen. Ne serait ce pas qu'une question de desinstall et reinstall des logiciels ?
Merci de ta réponse en tout cas
Re: Bluescreen
Tester les barrettes une par une est une bonne solution.
Fais-le tu en auras le cœur net.
Tene
Re: Bluescreen
Message par Tene »
Rien n'as changé.. toujours les mêmes écrans... ça devient pénible
On Mon 02/04/2012 14:31:38 GMT your computer crashed
Bugcheck code: 0x8E (0xFFFFFFFFC0000005, 0xFFFFFFFF92F276BC, 0xFFFFFFFFAF1649EC, 0x0)
On Mon 02/04/2012 11:19:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\040212-16239-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF9213A6BC, 0xFFFFFFFFB0EA7678, 0x0)
Re: Bluescreen
Désinstalle complètement Kaspersky avec RevoUninstaller par exemple.
Fais des tests et si tout va bien change d'antivirus.
Tene
Re: Bluescreen
Message par Tene »
C'est pas tant le souci de Kaspersky en fait car du coup je l'ai enlevé et ça va mieux..
C'est surtout le directx que je comprend pas, j'ai la dernière version mais je m'en tappe 2-3 par jour a cause du dxgmms1.sys
Re: Bluescreen
Il semble que la cause la plus courante soit un besoin de mise à jour non pas de directX mais du pilote de ta carte graphique.
Tene
Re: Bluescreen
Message par Tene »
J'ai fait l'analyse sur tout les drivers et j'ai tout mis a jour. Toujours le même problème, j'ai même eu un écran rose pendant un visionnage youtube ( sachant que mon écran a deux mois comme mon unité centrale et tout les composants )
Re: Bluescreen
Tu n'aurais pas une GT560 par hasard ?
Lis ce topic topic13008.html
