ecran bleu(causé par un drivers apparament)
bonjour tout le monde,depuis quelques jour mon ordinateur fait divers ecran bleu:
rapport whocrashed:
On Sun 24/07/2011 07:01:38 GMT your computer crashed
This was probably caused by the following module: ntkrpamp.exe (nt!KeBugCheckEx+0x1E)
Bugcheck code: 0x1A (0x41284, 0x4D6F001, 0x5027, 0xFFFFFFFFC0802000)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: ntkrpamp.exe .
Google query: ntkrpamp.exe MEMORY_MANAGEMENT
On Sat 23/07/2011 16:20:45 GMT your computer crashed
crash dump file: C:\Windows\Minidump\072311-39764-01.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0x8796F)
Bugcheck code: 0x19 (0x21, 0xFFFFFFFFB3EF7000, 0x1818, 0xFFFFFFFFB6D572F5)
Error: BAD_POOL_HEADER
file path: C:\Windows\system32\drivers\ntfs.sys
product: Système d’exploitation Microsoft® Windows®
description: Pilote du système de fichiers NT
Bug check description: This indicates that a pool header is corrupt.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
d'après whocrashed il semblerait que cela soit la cause d'un driver
j'ai aussi fait un scan memtest86+,aucune erreur et un scan chkdsk,celui ci a corriger quelques erreurs
merci d'avance de vos réponses!!
rapport whocrashed:
Re: ecran bleu(causé par un drivers apparament)
salut !
oui, un programme ou un driver fout le bazar, vas sur ma-config.com et fais un scan de ton matériel :
http://www.ma-config.com/
postes un rapport ici (centres toi sur l'onglet analyse des BSOD) .
bon j'ai creer un rapport au format pdf:
http://www.toofiles.com/fr/oip/document ... pport.html
j’espère que cela ira!
p.s:je pense savoir d'où vient le problème, cela viendrait peut-être de k9 web protection,mon Control parental qui plante de nombreuse fois depuis quelques jour et étonnamment cela a commencé dans les même moment
Tu pourrais commencer par essayer en désinstallant k9 web protection.
Fort possible qu'il y ait une incompatibilité.
nouveau ecran bleu:
On Sun 24/07/2011 16:08:13 GMT your computer crashed
crash dump file: C:\Windows\Minidump\072411-26551-01.dmp
This was probably caused by the following module: nltdi.sys (nltdi+0x787)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF834961AA, 0xFFFFFFFF9D9DB7E0, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
file path: C:\Program Files\NetLimiter 3\nltdi.sys
product: NetLimiter 3
company: Locktime Software
description: NetLimiter 3 TDI driver
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nltdi.sys (NetLimiter 3 TDI driver, Locktime Software).
Google query: nltdi.sys Locktime Software KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
juste après la désinstallation de k9 web protection!(avant que je clique sur redémarrer car il demandait de redémarrer)
Bonjour legendaire45
tu dois avoir le logiciel NetLimiter 3 d'installé et qui pose problème et peut-être voir ceci
http://www.microsofttranslator.com/BV.a ... roblems%2F
oui je l'ai installé, je l'utilise pour bloqué la connexion internet a certains processus sauf que cela fait 1 ans que je l'ai installé je vois pas pourquoi du jour au lendemain il causerait ces écrans bleus!!
nouceau bug freeze de l'ordinateur pendant la decompression d'un fichier rar de 4 go(avec 7-zip):
errreur dans le observateur d'event:
il ya 2 erreur qui se répete:
-event Disk:
Le périphérique \Device\Harddisk0\DR0 comporte un bloc défectueux.
-event nvstor32
Erreur de données sur le périphérique.
Périphérique : \Device\RaidPort0
Modèle : WDC WD6400AARS-00Y5B1
Version du microprogramme : 80.0
Numéro de série : WD-WCAV57379008
Port : 1
p.s:j'ai 2 disque dur, et je vient de chaanger celui de 640go(WDC WD6400AARS-00Y5B1) car il était defectueux.
p.p.s:j'ai aussi un mauvais codepage, dans cmd les é sont remplacer par des ù
-event Disk:
-event nvstor32
Port : 1
Modifié en dernier par legendaire45 le lun. 25 juil. 2011 12:32, modifié 3 fois.
que dois-je faire?
note:rapport de chkdsk sur le disque en question:
Windows a vérifié le système de fichiers sans trouver de problème.
382975999 Ko d’espace disque au total.
147240752 Ko dans 23934 fichiers.
5480 Ko dans 3031 index.
660 Ko dans des secteurs défectueux.
161875 Ko utilisés par le système.
65536 Ko occupés par le fichier journal.
235567232 Ko disponibles sur le disque.
4096 octets dans chaque unité d’allocation.
95743999 unités d’allocation au total sur le disque.
58891808 unités d’allocation disponibles sur le disque.
