Blue screen de plus en plus fréquent
fullmetalmoody
Depuis 2 mois le nombre d'écran bleu ne cesse d'augmenté, pourtant je mets très régulièrement à jour mes drivers ne prenant jamais de version bêta et je nettoie souvent mon pc avec ccleaner aussi bien la fonction nettoyeur d'applications que celle de registres.
Aujourd'hui j'ai eu 2 blue screen ce qui fait 2 de trop dans la journée.
Voila le rapport de WhoCrashed:
Crash Dump Analysis
On Mon 09/05/2011 09:24:03 GMT your computer crashed
crash dump file: C:\Windows\Minidump\050911-27424-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70740)
Bugcheck code: 0x50 (0xFFFFF3000A1F5600, 0x1, 0xFFFFF8800121F165, 0x7)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
This was probably caused by the following module: fltmgr.sys (fltmgr!FltGetStreamHandleContext+0xC75)
file path: C:\Windows\system32\drivers\fltmgr.sys
product: Système d’exploitation Microsoft® Windows®
description: Gestionnaire de filtres de système de fichiers Microsoft
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
Conclusion
2 crash dumps have been found and analyzed.
Merci de votre aide précieuse
Crash Dump Analysis
Conclusion
fullmetalmoody
Re: Blue screen de plus en plus fréquent
Voila mon blue screen du jour
On Tue 10/05/2011 10:30:09 GMT your computer crashed
This was probably caused by the following module: Unknown (0x6E24D474)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0x0, 0x8, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: Unknown .
Google query: Unknown KMODE_EXCEPTION_NOT_HANDLED
Conclusion
1 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
unknown
Conclusion
unknown
fullmetalmoody
Et encore deux à la suite ça devient très énervant, sachant que je n'ai aucun nouveau périphérique ni aucun problème trouvé
Crash Dump Analysis
On Tue 10/05/2011 15:34:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051011-26223-01.dmp
This was probably caused by the following module: unknown_module_00000000`00000002.sys (Unloaded_Unknown_Module_00000000`00000002+0x39)
Bugcheck code: 0x3B (0xC000001D, 0xFFFFFA8004ACD026, 0xFFFFF88008840950, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: unknown_module_00000000`00000002.sys .
Google query: unknown_module_00000000`00000002.sys SYSTEM_SERVICE_EXCEPTION
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
Crash Dump Analysis
Conclusion
Télécharge tdsskiller.zip
Décompresse l'archive et place TDSSKiller.exe sur le bureau.
Double clicque sur le fichier.
Sur l'écran clique sur le bouton Start scan
A la fin du scan, si des nuisibles sont détectés
Vérifie que l'option Cure est sélectionnée
Clique sur le bouton
Puis sur
Poste le contenu du rapport C:\TDSSKiller.Version_Date_Heure_log.txt
Télécharge tdsskiller.zip Décompresse l'archive et place TDSSKiller.exe sur le bureau.
Puis sur
fullmetalmoody
Merci de ton message et voila le txt:
2011/05/10 19:14:13.0300 2008 TDSS rootkit removing tool 2.5.0.0 May 1 2011 14:20:16
2011/05/10 19:14:13.0440 2008 ================================================================================
2011/05/10 19:14:13.0440 2008 SystemInfo:
2011/05/10 19:14:13.0440 2008 OS Version: 6.1.7600 ServicePack: 0.0
2011/05/10 19:14:13.0440 2008 Product type: Workstation
2011/05/10 19:14:13.0440 2008 ComputerName: MEHDI-PC
2011/05/10 19:14:13.0440 2008 UserName: Mehdi
2011/05/10 19:14:13.0440 2008 Windows directory: C:\Windows
2011/05/10 19:14:13.0440 2008 System windows directory: C:\Windows
2011/05/10 19:14:13.0440 2008 Running under WOW64
2011/05/10 19:14:13.0440 2008 Processor architecture: Intel x64
2011/05/10 19:14:13.0440 2008 Number of processors: 2
2011/05/10 19:14:13.0440 2008 Page size: 0x1000
2011/05/10 19:14:13.0440 2008 Boot type: Normal boot
2011/05/10 19:14:23.0315 2008 Initialize success
2011/05/10 19:14:34.0142 2500 ================================================================================
2011/05/10 19:14:34.0142 2500 Scan started
2011/05/10 19:14:34.0142 2500 Mode: Manual;
2011/05/10 19:14:34.0688 2500 1394ohci (1b00662092f9f9568b995902f0cc40d5) C:\Windows\system32\DRIVERS\1394ohci.sys
2011/05/10 19:14:34.0859 2500 ACPI (6f11e88748cdefd2f76aa215f97ddfe5) C:\Windows\system32\DRIVERS\ACPI.sys
2011/05/10 19:14:35.0062 2500 AcpiPmi (63b05a0420ce4bf0e4af6dcc7cada254) C:\Windows\system32\DRIVERS\acpipmi.sys
2011/05/10 19:14:35.0249 2500 adp94xx (2f6b34b83843f0c5118b63ac634f5bf4) C:\Windows\system32\DRIVERS\adp94xx.sys
2011/05/10 19:14:35.0468 2500 adpahci (597f78224ee9224ea1a13d6350ced962) C:\Windows\system32\DRIVERS\adpahci.sys
2011/05/10 19:14:35.0655 2500 adpu320 (e109549c90f62fb570b9540c4b148e54) C:\Windows\system32\DRIVERS\adpu320.sys
2011/05/10 19:14:35.0873 2500 AFD (b9384e03479d2506bc924c16a3db87bc) C:\Windows\system32\drivers\afd.sys
2011/05/10 19:14:36.0060 2500 agp440 (608c14dba7299d8cb6ed035a68a15799) C:\Windows\system32\DRIVERS\agp440.sys
2011/05/10 19:14:36.0248 2500 aliide (5812713a477a3ad7363c7438ca2ee038) C:\Windows\system32\DRIVERS\aliide.sys
2011/05/10 19:14:36.0450 2500 amdide (1ff8b4431c353ce385c875f194924c0c) C:\Windows\system32\DRIVERS\amdide.sys
2011/05/10 19:14:36.0638 2500 AmdK8 (7024f087cff1833a806193ef9d22cda9) C:\Windows\system32\DRIVERS\amdk8.sys
2011/05/10 19:14:36.0840 2500 AmdPPM (1e56388b3fe0d031c44144eb8c4d6217) C:\Windows\system32\DRIVERS\amdppm.sys
2011/05/10 19:14:37.0043 2500 amdsata (ec7ebab00a4d8448bab68d1e49b4beb9) C:\Windows\system32\drivers\amdsata.sys
2011/05/10 19:14:37.0246 2500 amdsbs (f67f933e79241ed32ff46a4f29b5120b) C:\Windows\system32\DRIVERS\amdsbs.sys
2011/05/10 19:14:37.0464 2500 amdxata (db27766102c7bf7e95140a2aa81d042e) C:\Windows\system32\drivers\amdxata.sys
2011/05/10 19:14:37.0652 2500 AppID (42fd751b27fa0e9c69bb39f39e409594) C:\Windows\system32\drivers\appid.sys
2011/05/10 19:14:37.0854 2500 arc (c484f8ceb1717c540242531db7845c4e) C:\Windows\system32\DRIVERS\arc.sys
2011/05/10 19:14:38.0057 2500 arcsas (019af6924aefe7839f61c830227fe79c) C:\Windows\system32\DRIVERS\arcsas.sys
2011/05/10 19:14:38.0244 2500 AsyncMac (769765ce2cc62867468cea93969b2242) C:\Windows\system32\DRIVERS\asyncmac.sys
2011/05/10 19:14:38.0447 2500 atapi (02062c0b390b7729edc9e69c680a6f3c) C:\Windows\system32\DRIVERS\atapi.sys
2011/05/10 19:14:38.0650 2500 b06bdrv (3e5b191307609f7514148c6832bb0842) C:\Windows\system32\DRIVERS\bxvbda.sys
2011/05/10 19:14:38.0853 2500 b57nd60a (b5ace6968304a3900eeb1ebfd9622df2) C:\Windows\system32\DRIVERS\b57nd60a.sys
2011/05/10 19:14:39.0087 2500 BCM43XX (9e84a931dbee0292e38ed672f6293a99) C:\Windows\system32\DRIVERS\bcmwl664.sys
2011/05/10 19:14:39.0305 2500 Beep (16a47ce2decc9b099349a5f840654746) C:\Windows\system32\drivers\Beep.sys
2011/05/10 19:14:39.0539 2500 blbdrive (61583ee3c3a17003c4acd0475646b4d3) C:\Windows\system32\DRIVERS\blbdrive.sys
2011/05/10 19:14:39.0820 2500 bowser (19d20159708e152267e53b66677a4995) C:\Windows\system32\DRIVERS\bowser.sys
2011/05/10 19:14:40.0101 2500 BrFiltLo (f09eee9edc320b5e1501f749fde686c8) C:\Windows\system32\DRIVERS\BrFiltLo.sys
2011/05/10 19:14:40.0288 2500 BrFiltUp (b114d3098e9bdb8bea8b053685831be6) C:\Windows\system32\DRIVERS\BrFiltUp.sys
2011/05/10 19:14:40.0491 2500 Brserid (43bea8d483bf1870f018e2d02e06a5bd) C:\Windows\System32\Drivers\Brserid.sys
2011/05/10 19:14:40.0678 2500 BrSerWdm (a6eca2151b08a09caceca35c07f05b42) C:\Windows\System32\Drivers\BrSerWdm.sys
2011/05/10 19:14:40.0881 2500 BrUsbMdm (b79968002c277e869cf38bd22cd61524) C:\Windows\System32\Drivers\BrUsbMdm.sys
2011/05/10 19:14:41.0068 2500 BrUsbSer (a87528880231c54e75ea7a44943b38bf) C:\Windows\System32\Drivers\BrUsbSer.sys
2011/05/10 19:14:41.0255 2500 BTHMODEM (9da669f11d1f894ab4eb69bf546a42e8) C:\Windows\system32\DRIVERS\bthmodem.sys
2011/05/10 19:14:41.0458 2500 cdfs (b8bd2bb284668c84865658c77574381a) C:\Windows\system32\DRIVERS\cdfs.sys
2011/05/10 19:14:41.0661 2500 cdrom (83d2d75e1efb81b3450c18131443f7db) C:\Windows\system32\DRIVERS\cdrom.sys
2011/05/10 19:14:41.0848 2500 circlass (d7cd5c4e1b71fa62050515314cfb52cf) C:\Windows\system32\DRIVERS\circlass.sys
2011/05/10 19:14:41.0988 2500 CLFS (fe1ec06f2253f691fe36217c592a0206) C:\Windows\system32\CLFS.sys
2011/05/10 19:14:42.0113 2500 CmBatt (0840155d0bddf1190f84a663c284bd33) C:\Windows\system32\DRIVERS\CmBatt.sys
2011/05/10 19:14:42.0316 2500 cmdide (e19d3f095812725d88f9001985b94edd) C:\Windows\system32\DRIVERS\cmdide.sys
2011/05/10 19:14:42.0503 2500 CNG (f95fd4cb7da00ba2a63ce9f6b5c053e1) C:\Windows\system32\Drivers\cng.sys
2011/05/10 19:14:42.0690 2500 Compbatt (102de219c3f61415f964c88e9085ad14) C:\Windows\system32\DRIVERS\compbatt.sys
2011/05/10 19:14:42.0862 2500 CompositeBus (f26b3a86f6fa87ca360b879581ab4123) C:\Windows\system32\DRIVERS\CompositeBus.sys
2011/05/10 19:14:43.0049 2500 crcdisk (1c827878a998c18847245fe1f34ee597) C:\Windows\system32\DRIVERS\crcdisk.sys
2011/05/10 19:14:43.0252 2500 CSC (4a6173c2279b498cd8f57cae504564cb) C:\Windows\system32\drivers\csc.sys
2011/05/10 19:14:43.0455 2500 DfsC (3f1dc527070acb87e40afe46ef6da749) C:\Windows\system32\Drivers\dfsc.sys
2011/05/10 19:14:43.0626 2500 discache (13096b05847ec78f0977f2c0f79e9ab3) C:\Windows\system32\drivers\discache.sys
2011/05/10 19:14:43.0798 2500 Disk (9819eee8b5ea3784ec4af3b137a5244c) C:\Windows\system32\DRIVERS\disk.sys
2011/05/10 19:14:44.0016 2500 Dot4 (b42ed0320c6e41102fde0005154849bb) C:\Windows\system32\DRIVERS\Dot4.sys
2011/05/10 19:14:44.0219 2500 Dot4Print (85135ad27e79b689335c08167d917cde) C:\Windows\system32\DRIVERS\Dot4Prt.sys
2011/05/10 19:14:44.0438 2500 dot4usb (fd05a02b0370bc3000f402e543ca5814) C:\Windows\system32\DRIVERS\dot4usb.sys
2011/05/10 19:14:44.0547 2500 driverhardwarev2x64 (3f9933fac064a84a293207f039860de7) C:\Program Files\ma-config.com\Drivers\driverhardwarev2x64.sys
2011/05/10 19:14:44.0765 2500 drmkaud (9b19f34400d24df84c858a421c205754) C:\Windows\system32\drivers\drmkaud.sys
2011/05/10 19:14:44.0999 2500 DXGKrnl (1633b9abf52784a1331476397a48cbef) C:\Windows\System32\drivers\dxgkrnl.sys
2011/05/10 19:14:45.0233 2500 ebdrv (dc5d737f51be844d8c82c695eb17372f) C:\Windows\system32\DRIVERS\evbda.sys
2011/05/10 19:14:45.0498 2500 elxstor (0e5da5369a0fcaea12456dd852545184) C:\Windows\system32\DRIVERS\elxstor.sys
2011/05/10 19:14:45.0701 2500 ErrDev (34a3c54752046e79a126e15c51db409b) C:\Windows\system32\DRIVERS\errdev.sys
2011/05/10 19:14:45.0904 2500 exfat (a510c654ec00c1e9bdd91eeb3a59823b) C:\Windows\system32\drivers\exfat.sys
2011/05/10 19:14:46.0091 2500 fastfat (0adc83218b66a6db380c330836f3e36d) C:\Windows\system32\drivers\fastfat.sys
2011/05/10 19:14:46.0294 2500 fdc (d765d19cd8ef61f650c384f62fac00ab) C:\Windows\system32\DRIVERS\fdc.sys
2011/05/10 19:14:46.0481 2500 FileInfo (655661be46b5f5f3fd454e2c3095b930) C:\Windows\system32\drivers\fileinfo.sys
2011/05/10 19:14:46.0668 2500 Filetrace (5f671ab5bc87eea04ec38a6cd5962a47) C:\Windows\system32\drivers\filetrace.sys
2011/05/10 19:14:46.0856 2500 flpydisk (c172a0f53008eaeb8ea33fe10e177af5) C:\Windows\system32\DRIVERS\flpydisk.sys
2011/05/10 19:14:47.0043 2500 FltMgr (f7866af72abbaf84b1fa5aa195378c59) C:\Windows\system32\drivers\fltmgr.sys
2011/05/10 19:14:47.0230 2500 FsDepends (d43703496149971890703b4b1b723eac) C:\Windows\system32\drivers\FsDepends.sys
2011/05/10 19:14:47.0417 2500 Fs_Rec (e95ef8547de20cf0603557c0cf7a9462) C:\Windows\system32\drivers\Fs_Rec.sys
2011/05/10 19:14:47.0604 2500 fvevol (ae87ba80d0ec3b57126ed2cdc15b24ed) C:\Windows\system32\DRIVERS\fvevol.sys
2011/05/10 19:14:47.0792 2500 gagp30kx (8c778d335c9d272cfd3298ab02abe3b6) C:\Windows\system32\DRIVERS\gagp30kx.sys
2011/05/10 19:14:47.0963 2500 hcw85cir (f2523ef6460fc42405b12248338ab2f0) C:\Windows\system32\drivers\hcw85cir.sys
2011/05/10 19:14:48.0166 2500 HdAudAddService (6410f6f415b2a5a9037224c41da8bf12) C:\Windows\system32\drivers\HdAudio.sys
2011/05/10 19:14:48.0369 2500 HDAudBus (0a49913402747a0b67de940fb42cbdbb) C:\Windows\system32\DRIVERS\HDAudBus.sys
2011/05/10 19:14:48.0540 2500 HidBatt (78e86380454a7b10a5eb255dc44a355f) C:\Windows\system32\DRIVERS\HidBatt.sys
2011/05/10 19:14:48.0712 2500 HidBth (7fd2a313f7afe5c4dab14798c48dd104) C:\Windows\system32\DRIVERS\hidbth.sys
2011/05/10 19:14:48.0868 2500 HidIr (0a77d29f311b88cfae3b13f9c1a73825) C:\Windows\system32\DRIVERS\hidir.sys
2011/05/10 19:14:49.0086 2500 HidUsb (b3bf6b5b50006def50b66306d99fcf6f) C:\Windows\system32\DRIVERS\hidusb.sys
2011/05/10 19:14:49.0274 2500 HpSAMD (0886d440058f203eba0e1825e4355914) C:\Windows\system32\DRIVERS\HpSAMD.sys
2011/05/10 19:14:49.0461 2500 HTTP (cee049cac4efa7f4e1e4ad014414a5d4) C:\Windows\system32\drivers\HTTP.sys
2011/05/10 19:14:49.0648 2500 hwpolicy (f17766a19145f111856378df337a5d79) C:\Windows\system32\drivers\hwpolicy.sys
2011/05/10 19:14:49.0835 2500 i8042prt (fa55c73d4affa7ee23ac4be53b4592d3) C:\Windows\system32\DRIVERS\i8042prt.sys
2011/05/10 19:14:50.0116 2500 iaStorV (b75e45c564e944a2657167d197ab29da) C:\Windows\system32\drivers\iaStorV.sys
2011/05/10 19:14:50.0428 2500 iirsp (5c18831c61933628f5bb0ea2675b9d21) C:\Windows\system32\DRIVERS\iirsp.sys
2011/05/10 19:14:50.0709 2500 IntcAzAudAddService (13089f31aa37cde1ce3784ee01a48484) C:\Windows\system32\drivers\RTKVHD64.sys
2011/05/10 19:14:50.0912 2500 intelide (f00f20e70c6ec3aa366910083a0518aa) C:\Windows\system32\DRIVERS\intelide.sys
2011/05/10 19:14:51.0083 2500 intelppm (ada036632c664caa754079041cf1f8c1) C:\Windows\system32\DRIVERS\intelppm.sys
2011/05/10 19:14:51.0286 2500 IpFilterDriver (722dd294df62483cecaae6e094b4d695) C:\Windows\system32\DRIVERS\ipfltdrv.sys
2011/05/10 19:14:51.0473 2500 IPMIDRV (e2b4a4494db7cb9b89b55ca268c337c5) C:\Windows\system32\DRIVERS\IPMIDrv.sys
2011/05/10 19:14:51.0660 2500 IPNAT (af9b39a7e7b6caa203b3862582e9f2d0) C:\Windows\system32\drivers\ipnat.sys
2011/05/10 19:14:51.0848 2500 IRENUM (3abf5e7213eb28966d55d58b515d5ce9) C:\Windows\system32\drivers\irenum.sys
2011/05/10 19:14:52.0035 2500 isapnp (2f7b28dc3e1183e5eb418df55c204f38) C:\Windows\system32\DRIVERS\isapnp.sys
2011/05/10 19:14:52.0222 2500 iScsiPrt (fa4d2557de56d45b0a346f93564be6e1) C:\Windows\system32\DRIVERS\msiscsi.sys
2011/05/10 19:14:52.0425 2500 kbdclass (bc02336f1cba7dcc7d1213bb588a68a5) C:\Windows\system32\DRIVERS\kbdclass.sys
2011/05/10 19:14:52.0596 2500 kbdhid (6def98f8541e1b5dceb2c822a11f7323) C:\Windows\system32\DRIVERS\kbdhid.sys
2011/05/10 19:14:52.0799 2500 KSecDD (e8b6fcc9c83535c67f835d407620bd27) C:\Windows\system32\Drivers\ksecdd.sys
2011/05/10 19:14:52.0986 2500 KSecPkg (a8c63880ef6f4d3fec7b616b9c060215) C:\Windows\system32\Drivers\ksecpkg.sys
2011/05/10 19:14:53.0174 2500 ksthunk (6869281e78cb31a43e969f06b57347c4) C:\Windows\system32\drivers\ksthunk.sys
2011/05/10 19:14:53.0376 2500 lltdio (1538831cf8ad2979a04c423779465827) C:\Windows\system32\DRIVERS\lltdio.sys
2011/05/10 19:14:53.0579 2500 LSI_FC (1a93e54eb0ece102495a51266dcdb6a6) C:\Windows\system32\DRIVERS\lsi_fc.sys
2011/05/10 19:14:53.0751 2500 LSI_SAS (1047184a9fdc8bdbff857175875ee810) C:\Windows\system32\DRIVERS\lsi_sas.sys
2011/05/10 19:14:53.0938 2500 LSI_SAS2 (30f5c0de1ee8b5bc9306c1f0e4a75f93) C:\Windows\system32\DRIVERS\lsi_sas2.sys
2011/05/10 19:14:54.0125 2500 LSI_SCSI (0504eacaff0d3c8aed161c4b0d369d4a) C:\Windows\system32\DRIVERS\lsi_scsi.sys
2011/05/10 19:14:54.0328 2500 luafv (43d0f98e1d56ccddb0d5254cff7b356e) C:\Windows\system32\drivers\luafv.sys
2011/05/10 19:14:54.0531 2500 megasas (a55805f747c6edb6a9080d7c633bd0f4) C:\Windows\system32\DRIVERS\megasas.sys
2011/05/10 19:14:54.0718 2500 MegaSR (baf74ce0072480c3b6b7c13b2a94d6b3) C:\Windows\system32\DRIVERS\MegaSR.sys
2011/05/10 19:14:54.0952 2500 Modem (800ba92f7010378b09f9ed9270f07137) C:\Windows\system32\drivers\modem.sys
2011/05/10 19:14:55.0139 2500 monitor (b03d591dc7da45ece20b3b467e6aadaa) C:\Windows\system32\DRIVERS\monitor.sys
2011/05/10 19:14:55.0342 2500 mouclass (7d27ea49f3c1f687d357e77a470aea99) C:\Windows\system32\DRIVERS\mouclass.sys
2011/05/10 19:14:55.0514 2500 mouhid (d3bf052c40b0c4166d9fd86a4288c1e6) C:\Windows\system32\DRIVERS\mouhid.sys
2011/05/10 19:14:55.0701 2500 mountmgr (791af66c4d0e7c90a3646066386fb571) C:\Windows\system32\drivers\mountmgr.sys
2011/05/10 19:14:55.0904 2500 MpFilter (e6ba8e5a4a871899e23d64573ef58ee9) C:\Windows\system32\DRIVERS\MpFilter.sys
2011/05/10 19:14:56.0106 2500 mpio (609d1d87649ecc19796f4d76d4c15cea) C:\Windows\system32\DRIVERS\mpio.sys
2011/05/10 19:14:56.0309 2500 MpNWMon (98b09a4f2c462441030b83a80a3f6fb3) C:\Windows\system32\DRIVERS\MpNWMon.sys
2011/05/10 19:14:56.0496 2500 mpsdrv (6c38c9e45ae0ea2fa5e551f2ed5e978f) C:\Windows\system32\drivers\mpsdrv.sys
2011/05/10 19:14:56.0699 2500 MRxDAV (30524261bb51d96d6fcbac20c810183c) C:\Windows\system32\drivers\mrxdav.sys
2011/05/10 19:14:56.0886 2500 mrxsmb (b7f3d2c40bdf8ffb73ebfb19c77734e2) C:\Windows\system32\DRIVERS\mrxsmb.sys
2011/05/10 19:14:57.0105 2500 mrxsmb10 (86c6f88b5168ce21cf8d69d0b3ff5d19) C:\Windows\system32\DRIVERS\mrxsmb10.sys
2011/05/10 19:14:57.0323 2500 mrxsmb20 (b081069251c8e9f42cb8769d07148f9c) C:\Windows\system32\DRIVERS\mrxsmb20.sys
2011/05/10 19:14:57.0526 2500 msahci (5c37497276e3b3a5488b23a326a754b7) C:\Windows\system32\DRIVERS\msahci.sys
2011/05/10 19:14:57.0729 2500 msdsm (8d27b597229aed79430fb9db3bcbfbd0) C:\Windows\system32\DRIVERS\msdsm.sys
2011/05/10 19:14:57.0932 2500 Msfs (aa3fb40e17ce1388fa1bedab50ea8f96) C:\Windows\system32\drivers\Msfs.sys
2011/05/10 19:14:58.0103 2500 mshidkmdf (f9d215a46a8b9753f61767fa72a20326) C:\Windows\System32\drivers\mshidkmdf.sys
2011/05/10 19:14:58.0306 2500 msisadrv (d916874bbd4f8b07bfb7fa9b3ccae29d) C:\Windows\system32\DRIVERS\msisadrv.sys
2011/05/10 19:14:58.0493 2500 MSKSSRV (49ccf2c4fea34ffad8b1b59d49439366) C:\Windows\system32\drivers\MSKSSRV.sys
2011/05/10 19:14:58.0712 2500 MSPCLOCK (bdd71ace35a232104ddd349ee70e1ab3) C:\Windows\system32\drivers\MSPCLOCK.sys
2011/05/10 19:14:58.0899 2500 MSPQM (4ed981241db27c3383d72092b618a1d0) C:\Windows\system32\drivers\MSPQM.sys
2011/05/10 19:14:59.0102 2500 MsRPC (89cb141aa8616d8c6a4610fa26c60964) C:\Windows\system32\drivers\MsRPC.sys
2011/05/10 19:14:59.0289 2500 mssmbios (0eed230e37515a0eaee3c2e1bc97b288) C:\Windows\system32\DRIVERS\mssmbios.sys
2011/05/10 19:14:59.0476 2500 MSTEE (2e66f9ecb30b4221a318c92ac2250779) C:\Windows\system32\drivers\MSTEE.sys
2011/05/10 19:14:59.0663 2500 MTConfig (7ea404308934e675bffde8edf0757bcd) C:\Windows\system32\DRIVERS\MTConfig.sys
2011/05/10 19:14:59.0850 2500 Mup (f9a18612fd3526fe473c1bda678d61c8) C:\Windows\system32\Drivers\mup.sys
2011/05/10 19:15:00.0053 2500 NativeWifiP (1ea3749c4114db3e3161156ffffa6b33) C:\Windows\system32\DRIVERS\nwifi.sys
2011/05/10 19:15:00.0240 2500 NDIS (cad515dbd07d082bb317d9928ce8962c) C:\Windows\system32\drivers\ndis.sys
2011/05/10 19:15:00.0615 2500 NdisCap (9f9a1f53aad7da4d6fef5bb73ab811ac) C:\Windows\system32\DRIVERS\ndiscap.sys
2011/05/10 19:15:00.0802 2500 NdisTapi (30639c932d9fef22b31268fe25a1b6e5) C:\Windows\system32\DRIVERS\ndistapi.sys
2011/05/10 19:15:00.0989 2500 Ndisuio (f105ba1e22bf1f2ee8f005d4305e4bec) C:\Windows\system32\DRIVERS\ndisuio.sys
2011/05/10 19:15:01.0176 2500 NdisWan (557dfab9ca1fcb036ac77564c010dad3) C:\Windows\system32\DRIVERS\ndiswan.sys
2011/05/10 19:15:01.0395 2500 NDProxy (659b74fb74b86228d6338d643cd3e3cf) C:\Windows\system32\drivers\NDProxy.sys
2011/05/10 19:15:01.0598 2500 NetBIOS (86743d9f5d2b1048062b14b1d84501c4) C:\Windows\system32\DRIVERS\netbios.sys
2011/05/10 19:15:01.0816 2500 NetBT (9162b273a44ab9dce5b44362731d062a) C:\Windows\system32\DRIVERS\netbt.sys
2011/05/10 19:15:02.0019 2500 nfrd960 (77889813be4d166cdab78ddba990da92) C:\Windows\system32\DRIVERS\nfrd960.sys
2011/05/10 19:15:02.0206 2500 NisDrv (3713e8452b88d3e0be095e06b6fbc776) C:\Windows\system32\DRIVERS\NisDrvWFP.sys
2011/05/10 19:15:02.0424 2500 Npfs (1e4c4ab5c9b8dd13179bbdc75a2a01f7) C:\Windows\system32\drivers\Npfs.sys
2011/05/10 19:15:02.0612 2500 nsiproxy (e7f5ae18af4168178a642a9247c63001) C:\Windows\system32\drivers\nsiproxy.sys
2011/05/10 19:15:02.0814 2500 Ntfs (378e0e0dfea67d98ae6ea53adbbd76bc) C:\Windows\system32\drivers\Ntfs.sys
2011/05/10 19:15:03.0033 2500 Null (9899284589f75fa8724ff3d16aed75c1) C:\Windows\system32\drivers\Null.sys
2011/05/10 19:15:03.0251 2500 NVHDA (f2662fdc20518ee8a8eed4f61ba42349) C:\Windows\system32\drivers\nvhda64v.sys
2011/05/10 19:15:03.0641 2500 nvlddmkm (a963c2c276a97b088ded5d7a83be8052) C:\Windows\system32\DRIVERS\nvlddmkm.sys
2011/05/10 19:15:03.0891 2500 nvraid (a4d9c9a608a97f59307c2f2600edc6a4) C:\Windows\system32\drivers\nvraid.sys
2011/05/10 19:15:04.0094 2500 nvstor (6c1d5f70e7a6a3fd1c90d840edc048b9) C:\Windows\system32\drivers\nvstor.sys
2011/05/10 19:15:04.0312 2500 nv_agp (270d7cd42d6e3979f6dd0146650f0e05) C:\Windows\system32\DRIVERS\nv_agp.sys
2011/05/10 19:15:04.0499 2500 ohci1394 (3589478e4b22ce21b41fa1bfc0b8b8a0) C:\Windows\system32\DRIVERS\ohci1394.sys
2011/05/10 19:15:04.0733 2500 Parport (0086431c29c35be1dbc43f52cc273887) C:\Windows\system32\DRIVERS\parport.sys
2011/05/10 19:15:04.0920 2500 partmgr (7daa117143316c4a1537e074a5a9eaf0) C:\Windows\system32\drivers\partmgr.sys
2011/05/10 19:15:05.0123 2500 pci (f36f6504009f2fb0dfd1b17a116ad74b) C:\Windows\system32\DRIVERS\pci.sys
2011/05/10 19:15:05.0310 2500 pciide (b5b8b5ef2e5cb34df8dcf8831e3534fa) C:\Windows\system32\DRIVERS\pciide.sys
2011/05/10 19:15:05.0498 2500 pcmcia (b2e81d4e87ce48589f98cb8c05b01f2f) C:\Windows\system32\DRIVERS\pcmcia.sys
2011/05/10 19:15:05.0778 2500 pcw (d6b9c2e1a11a3a4b26a182ffef18f603) C:\Windows\system32\drivers\pcw.sys
2011/05/10 19:15:06.0059 2500 PEAUTH (68769c3356b3be5d1c732c97b9a80d6e) C:\Windows\system32\drivers\peauth.sys
2011/05/10 19:15:06.0293 2500 PptpMiniport (27cc19e81ba5e3403c48302127bda717) C:\Windows\system32\DRIVERS\raspptp.sys
2011/05/10 19:15:06.0496 2500 Processor (0d922e23c041efb1c3fac2a6f943c9bf) C:\Windows\system32\DRIVERS\processr.sys
2011/05/10 19:15:06.0683 2500 Psched (ee992183bd8eaefd9973f352e587a299) C:\Windows\system32\DRIVERS\pacer.sys
2011/05/10 19:15:06.0870 2500 ql2300 (a53a15a11ebfd21077463ee2c7afeef0) C:\Windows\system32\DRIVERS\ql2300.sys
2011/05/10 19:15:07.0120 2500 ql40xx (4f6d12b51de1aaeff7dc58c4d75423c8) C:\Windows\system32\DRIVERS\ql40xx.sys
2011/05/10 19:15:07.0307 2500 QWAVEdrv (76707bb36430888d9ce9d705398adb6c) C:\Windows\system32\drivers\qwavedrv.sys
2011/05/10 19:15:07.0510 2500 RasAcd (5a0da8ad5762fa2d91678a8a01311704) C:\Windows\system32\DRIVERS\rasacd.sys
2011/05/10 19:15:07.0775 2500 RasAgileVpn (7ecff9b22276b73f43a99a15a6094e90) C:\Windows\system32\DRIVERS\AgileVpn.sys
2011/05/10 19:15:08.0025 2500 Rasl2tp (87a6e852a22991580d6d39adc4790463) C:\Windows\system32\DRIVERS\rasl2tp.sys
2011/05/10 19:15:08.0368 2500 RasPppoe (855c9b1cd4756c5e9a2aa58a15f58c25) C:\Windows\system32\DRIVERS\raspppoe.sys
2011/05/10 19:15:08.0618 2500 RasSstp (e8b1e447b008d07ff47d016c2b0eeecb) C:\Windows\system32\DRIVERS\rassstp.sys
2011/05/10 19:15:08.0961 2500 rdbss (3bac8142102c15d59a87757c1d41dce5) C:\Windows\system32\DRIVERS\rdbss.sys
2011/05/10 19:15:09.0257 2500 rdpbus (302da2a0539f2cf54d7c6cc30c1f2d8d) C:\Windows\system32\DRIVERS\rdpbus.sys
2011/05/10 19:15:09.0585 2500 RDPCDD (cea6cc257fc9b7715f1c2b4849286d24) C:\Windows\system32\DRIVERS\RDPCDD.sys
2011/05/10 19:15:09.0990 2500 RDPDR (9706b84dbabfc4b4ca46c5a82b14dfa3) C:\Windows\system32\drivers\rdpdr.sys
2011/05/10 19:15:10.0193 2500 RDPENCDD (bb5971a4f00659529a5c44831af22365) C:\Windows\system32\drivers\rdpencdd.sys
2011/05/10 19:15:10.0427 2500 RDPREFMP (216f3fa57533d98e1f74ded70113177a) C:\Windows\system32\drivers\rdprefmp.sys
2011/05/10 19:15:10.0630 2500 RDPWD (8a3e6bea1c53ea6177fe2b6eba2c80d7) C:\Windows\system32\drivers\RDPWD.sys
2011/05/10 19:15:10.0817 2500 rdyboost (634b9a2181d98f15941236886164ec8b) C:\Windows\system32\drivers\rdyboost.sys
2011/05/10 19:15:11.0379 2500 rspndr (ddc86e4f8e7456261e637e3552e804ff) C:\Windows\system32\DRIVERS\rspndr.sys
2011/05/10 19:15:11.0706 2500 RTL8167 (baefee35d27a5440d35092ce10267bec) C:\Windows\system32\DRIVERS\Rt64win7.sys
2011/05/10 19:15:11.0972 2500 RTL85n64 (13c34adbfefb199c8b185ba0919532f4) C:\Windows\system32\DRIVERS\RTL85n64.sys
2011/05/10 19:15:12.0190 2500 s3cap (88af6e02ab19df7fd07ecdf9c91e9af6) C:\Windows\system32\DRIVERS\vms3cap.sys
2011/05/10 19:15:12.0533 2500 sbp2port (e3bbb89983daf5622c1d50cf49f28227) C:\Windows\system32\DRIVERS\sbp2port.sys
2011/05/10 19:15:12.0720 2500 scfilter (c94da20c7e3ba1dca269bc8460d98387) C:\Windows\system32\DRIVERS\scfilter.sys
2011/05/10 19:15:12.0954 2500 sdbus (2c8d162efaf73abd36d8bcbb6340cae7) C:\Windows\system32\DRIVERS\sdbus.sys
2011/05/10 19:15:13.0251 2500 secdrv (3ea8a16169c26afbeb544e0e48421186) C:\Windows\system32\drivers\secdrv.sys
2011/05/10 19:15:13.0563 2500 Serenum (cb624c0035412af0debec78c41f5ca1b) C:\Windows\system32\DRIVERS\serenum.sys
2011/05/10 19:15:13.0766 2500 Serial (c1d8e28b2c2adfaec4ba89e9fda69bd6) C:\Windows\system32\DRIVERS\serial.sys
2011/05/10 19:15:13.0953 2500 sermouse (1c545a7d0691cc4a027396535691c3e3) C:\Windows\system32\DRIVERS\sermouse.sys
2011/05/10 19:15:14.0156 2500 sffdisk (a554811bcd09279536440c964ae35bbf) C:\Windows\system32\DRIVERS\sffdisk.sys
2011/05/10 19:15:14.0390 2500 sffp_mmc (ff414f0baefeba59bc6c04b3db0b87bf) C:\Windows\system32\DRIVERS\sffp_mmc.sys
2011/05/10 19:15:14.0577 2500 sffp_sd (178298f767fe638c9fedcbdef58bb5e4) C:\Windows\system32\DRIVERS\sffp_sd.sys
2011/05/10 19:15:14.0764 2500 sfloppy (a9d601643a1647211a1ee2ec4e433ff4) C:\Windows\system32\DRIVERS\sfloppy.sys
2011/05/10 19:15:14.0951 2500 SiSRaid2 (843caf1e5fde1ffd5ff768f23a51e2e1) C:\Windows\system32\DRIVERS\SiSRaid2.sys
2011/05/10 19:15:15.0154 2500 SiSRaid4 (6a6c106d42e9ffff8b9fcb4f754f6da4) C:\Windows\system32\DRIVERS\sisraid4.sys
2011/05/10 19:15:15.0341 2500 Smb (548260a7b8654e024dc30bf8a7c5baa4) C:\Windows\system32\DRIVERS\smb.sys
2011/05/10 19:15:15.0560 2500 spldr (b9e31e5cacdfe584f34f730a677803f9) C:\Windows\system32\drivers\spldr.sys
2011/05/10 19:15:15.0918 2500 sptd (4b3f898dc1378ced2f35d04e5b0ce0df) C:\Windows\System32\Drivers\sptd.sys
2011/05/10 19:15:15.0918 2500 Suspicious file (NoAccess): C:\Windows\System32\Drivers\sptd.sys. md5: 4b3f898dc1378ced2f35d04e5b0ce0df
2011/05/10 19:15:15.0934 2500 sptd - detected LockedFile.Multi.Generic (1)
2011/05/10 19:15:16.0184 2500 srv (148d50904d2a0df29a19778715eb35bb) C:\Windows\system32\DRIVERS\srv.sys
2011/05/10 19:15:17.0151 2500 srv2 (ce2189fe31d36678ac9eb7ddee08ec96) C:\Windows\system32\DRIVERS\srv2.sys
2011/05/10 19:15:17.0354 2500 srvnet (cb69edeb069a49577592835659cd0e46) C:\Windows\system32\DRIVERS\srvnet.sys
2011/05/10 19:15:17.0556 2500 stexstor (f3817967ed533d08327dc73bc4d5542a) C:\Windows\system32\DRIVERS\stexstor.sys
2011/05/10 19:15:17.0744 2500 storflt (ffd7a6f15b14234b5b0e5d49e7961895) C:\Windows\system32\DRIVERS\vmstorfl.sys
2011/05/10 19:15:17.0931 2500 storvsc (8fccbefc5c440b3c23454656e551b09a) C:\Windows\system32\DRIVERS\storvsc.sys
2011/05/10 19:15:18.0102 2500 swenum (d01ec09b6711a5f8e7e6564a4d0fbc90) C:\Windows\system32\DRIVERS\swenum.sys
2011/05/10 19:15:18.0321 2500 Tcpip (90a2d722cf64d911879d6c4a4f802a4d) C:\Windows\system32\drivers\tcpip.sys
2011/05/10 19:15:18.0570 2500 TCPIP6 (90a2d722cf64d911879d6c4a4f802a4d) C:\Windows\system32\DRIVERS\tcpip.sys
2011/05/10 19:15:18.0820 2500 tcpipreg (76d078af6f587b162d50210f761eb9ed) C:\Windows\system32\drivers\tcpipreg.sys
2011/05/10 19:15:19.0148 2500 TDPIPE (3371d21011695b16333a3934340c4e7c) C:\Windows\system32\drivers\tdpipe.sys
2011/05/10 19:15:19.0335 2500 TDTCP (e4245bda3190a582d55ed09e137401a9) C:\Windows\system32\drivers\tdtcp.sys
2011/05/10 19:15:19.0522 2500 tdx (079125c4b17b01fcaeebce0bcb290c0f) C:\Windows\system32\DRIVERS\tdx.sys
2011/05/10 19:15:19.0709 2500 TermDD (c448651339196c0e869a355171875522) C:\Windows\system32\DRIVERS\termdd.sys
2011/05/10 19:15:19.0959 2500 tssecsrv (61b96c26131e37b24e93327a0bd1fb95) C:\Windows\system32\DRIVERS\tssecsrv.sys
2011/05/10 19:15:20.0146 2500 tunnel (3836171a2cdf3af8ef10856db9835a70) C:\Windows\system32\DRIVERS\tunnel.sys
2011/05/10 19:15:20.0364 2500 uagp35 (b4dd609bd7e282bfc683cec7eaaaad67) C:\Windows\system32\DRIVERS\uagp35.sys
2011/05/10 19:15:20.0552 2500 udfs (d47baead86c65d4f4069d7ce0a4edceb) C:\Windows\system32\DRIVERS\udfs.sys
2011/05/10 19:15:20.0754 2500 uliagpkx (4bfe1bc28391222894cbf1e7d0e42320) C:\Windows\system32\DRIVERS\uliagpkx.sys
2011/05/10 19:15:20.0942 2500 umbus (eab6c35e62b1b0db0d1b48b671d3a117) C:\Windows\system32\DRIVERS\umbus.sys
2011/05/10 19:15:21.0144 2500 UmPass (b2e8e8cb557b156da5493bbddcc1474d) C:\Windows\system32\DRIVERS\umpass.sys
2011/05/10 19:15:21.0332 2500 usbccgp (b26afb54a534d634523c4fb66765b026) C:\Windows\system32\DRIVERS\usbccgp.sys
2011/05/10 19:15:21.0519 2500 usbcir (af0892a803fdda7492f595368e3b68e7) C:\Windows\system32\DRIVERS\usbcir.sys
2011/05/10 19:15:21.0706 2500 usbehci (2ea4aff7be7eb4632e3aa8595b0803b5) C:\Windows\system32\DRIVERS\usbehci.sys
2011/05/10 19:15:21.0924 2500 usbhub (4c9042b8df86c1e8e6240c218b99b39b) C:\Windows\system32\DRIVERS\usbhub.sys
2011/05/10 19:15:22.0112 2500 usbohci (58e546bbaf87664fc57e0f6081e4f609) C:\Windows\system32\DRIVERS\usbohci.sys
2011/05/10 19:15:22.0470 2500 usbprint (73188f58fb384e75c4063d29413cee3d) C:\Windows\system32\DRIVERS\usbprint.sys
2011/05/10 19:15:22.0658 2500 usbscan (aaa2513c8aed8b54b189fd0c6b1634c0) C:\Windows\system32\DRIVERS\usbscan.sys
2011/05/10 19:15:22.0845 2500 USBSTOR (f39983647bc1f3e6100778ddfe9dce29) C:\Windows\system32\DRIVERS\USBSTOR.SYS
2011/05/10 19:15:23.0032 2500 usbuhci (81fb2216d3a60d1284455d511797db3d) C:\Windows\system32\DRIVERS\usbuhci.sys
2011/05/10 19:15:23.0235 2500 usbvideo (7cb8c573c6e4a2714402cc0a36eab4fe) C:\Windows\System32\Drivers\usbvideo.sys
2011/05/10 19:15:23.0422 2500 vdrvroot (c5c876ccfc083ff3b128f933823e87bd) C:\Windows\system32\DRIVERS\vdrvroot.sys
2011/05/10 19:15:23.0609 2500 vga (da4da3f5e02943c2dc8c6ed875de68dd) C:\Windows\system32\DRIVERS\vgapnp.sys
2011/05/10 19:15:23.0796 2500 VgaSave (53e92a310193cb3c03bea963de7d9cfc) C:\Windows\System32\drivers\vga.sys
2011/05/10 19:15:23.0984 2500 vhdmp (c82e748660f62a242b2dfac1442f22a4) C:\Windows\system32\DRIVERS\vhdmp.sys
2011/05/10 19:15:24.0171 2500 viaide (e5689d93ffe4e5d66c0178761240dd54) C:\Windows\system32\DRIVERS\viaide.sys
2011/05/10 19:15:24.0358 2500 vmbus (1501699d7eda984abc4155a7da5738d1) C:\Windows\system32\DRIVERS\vmbus.sys
2011/05/10 19:15:24.0545 2500 VMBusHID (ae10c35761889e65a6f7176937c5592c) C:\Windows\system32\DRIVERS\VMBusHID.sys
2011/05/10 19:15:24.0732 2500 volmgr (2b1a3dae2b4e70dbba822b7a03fbd4a3) C:\Windows\system32\DRIVERS\volmgr.sys
2011/05/10 19:15:24.0920 2500 volmgrx (99b0cbb569ca79acaed8c91461d765fb) C:\Windows\system32\drivers\volmgrx.sys
2011/05/10 19:15:25.0122 2500 volsnap (58f82eed8ca24b461441f9c3e4f0bf5c) C:\Windows\system32\DRIVERS\volsnap.sys
2011/05/10 19:15:25.0310 2500 vsmraid (5e2016ea6ebaca03c04feac5f330d997) C:\Windows\system32\DRIVERS\vsmraid.sys
2011/05/10 19:15:25.0512 2500 vwifibus (36d4720b72b5c5d9cb2b9c29e9df67a1) C:\Windows\system32\DRIVERS\vwifibus.sys
2011/05/10 19:15:25.0715 2500 vwififlt (6a3d66263414ff0d6fa754c646612f3f) C:\Windows\system32\DRIVERS\vwififlt.sys
2011/05/10 19:15:25.0902 2500 WacomPen (4e9440f4f152a7b944cb1663d3935a3e) C:\Windows\system32\DRIVERS\wacompen.sys
2011/05/10 19:15:26.0105 2500 WANARP (47ca49400643effd3f1c9a27e1d69324) C:\Windows\system32\DRIVERS\wanarp.sys
2011/05/10 19:15:26.0121 2500 Wanarpv6 (47ca49400643effd3f1c9a27e1d69324) C:\Windows\system32\DRIVERS\wanarp.sys
2011/05/10 19:15:26.0355 2500 Wd (72889e16ff12ba0f235467d6091b17dc) C:\Windows\system32\DRIVERS\wd.sys
2011/05/10 19:15:26.0558 2500 Wdf01000 (441bd2d7b4f98134c3a4f9fa570fd250) C:\Windows\system32\drivers\Wdf01000.sys
2011/05/10 19:15:26.0760 2500 WfpLwf (611b23304bf067451a9fdee01fbdd725) C:\Windows\system32\DRIVERS\wfplwf.sys
2011/05/10 19:15:26.0948 2500 WIMMount (05ecaec3e4529a7153b3136ceb49f0ec) C:\Windows\system32\drivers\wimmount.sys
2011/05/10 19:15:27.0182 2500 WmiAcpi (f6ff8944478594d0e414d3f048f0d778) C:\Windows\system32\DRIVERS\wmiacpi.sys
2011/05/10 19:15:27.0509 2500 ws2ifsl (6bcc1d7d2fd2453957c5479a32364e52) C:\Windows\system32\drivers\ws2ifsl.sys
2011/05/10 19:15:27.0790 2500 WudfPf (7cadc74271dd6461c452c271b30bd378) C:\Windows\system32\drivers\WudfPf.sys
2011/05/10 19:15:27.0977 2500 WUDFRd (3b197af0fff08aa66b6b2241ca538d64) C:\Windows\system32\DRIVERS\WUDFRd.sys
2011/05/10 19:15:28.0040 2500 ================================================================================
2011/05/10 19:15:28.0040 2500 Scan finished
2011/05/10 19:15:28.0040 3864 Detected object count: 1
2011/05/10 19:15:57.0945 3864 HKLM\SYSTEM\ControlSet001\services\sptd - will be deleted after reboot
2011/05/10 19:15:58.0007 3864 C:\Windows\System32\Drivers\sptd.sys - will be deleted after reboot
2011/05/10 19:15:58.0007 3864 LockedFile.Multi.Generic(sptd) - User select action: Delete
2011/05/10 19:16:02.0547 2748 Deinitialize success
Windows m'a dit que le driver s'était installé avec succès maintenant j'espère que c'est réglé
Je vous tiens au courant
fullmetalmoody
Fausse joie, presque 24 h de répit mais voila :
Crash Dump Analysis
On Wed 11/05/2011 09:12:40 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051111-25552-01.dmp
This was probably caused by the following module: rtl85n64.sys (RTL85n64+0x10636E)
Bugcheck code: 0xD1 (0x2B839337, 0x2, 0x1, 0xFFFFF8800697C36E)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\rtl85n64.sys
product: Realtek 8180/8185 Wireless Adapters
company: Realtek Semiconductor Corporation
description: Realtek 8180/8185 Wireless Device
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: rtl85n64.sys (Realtek 8180/8185 Wireless Device, Realtek Semiconductor Corporation ).
Google query: rtl85n64.sys Realtek Semiconductor Corporation DRIVER_IRQL_NOT_LESS_OR_EQUAL
Conclusion
2 crash dumps have been found and analyzed. 2 third party drivers have been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
Crash Dump Analysis
Conclusion
Cette fois il s'agit nommément de ta carte réseau Wi-Fi Realtek qui est en cause.
Recherche les pilotes sur le site du constructeur de ton pc, désinstalle celui qui est en place et réinstalle les nouveaux.
fullmetalmoody
Ok je vais essayer
fullmetalmoody
Ca n'a rien donné, j'ai installé le dernier driver realtek et c'est toujours pareil:
Crash Dump Analysis
On Sat 14/05/2011 08:56:13 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051411-26395-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70700)
Bugcheck code: 0x50 (0xFFFFF87F912468B0, 0x1, 0xFFFFF80003085750, 0x5)
Conclusion
3 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
Crash Dump Analysis
Conclusion
PC-ACCOMPAGNE
Bonjour,fullmetalmoody a écrit :Depuis 2 mois le nombre d'écran bleu ne cesse d'augmenté, pourtant je mets très régulièrement à jour mes drivers ne prenant jamais de version bêta et je nettoie souvent mon pc avec ccleaner aussi bien la fonction nettoyeur d'applications que celle de registres.
je commencerais par vous dire que vous ne faites peut être pas les choses les plus indiquées ????
C'est un avis qui n'est pas unanimement partagé mais je suis résolument CONTRE les nettoyages de registres avec des outils "semi-automatisés" par des gens qui, pour avertis qu'ils puissent être, ne sont pas des experts.
Le nettoyage de registre qui se justifiait pleinement sous win98, est devenu, depuis xp,"superflu" voire dangereux.
Google vous donnera des tas d'infos la dessus, mais retenez que vous ne nuirez pas au bon fonctionnement de votre machine en arretant ces opérations de nettoyage registre, au contraire, vous lui rendrez service.
Continuez donc à utiliser ccleaner pour ce qu'il est de bien, le nettoyage des fichiers temporaires, internet et autres raccourcis de fichiers récents.
Et réservez donc le nettoyage registre à des opérations spécifiques de désinstallations "pointues", en vous faisant éventuellement assister. Et encore, il existe des tas d'utilitaires pour toutes ces opérations pointues qui permettent de quasiment ne rien avoir à faire de plus (désinstallatin d'antivirus, de drivers d'affichage, etc.)
Pour vos drivers, sauf problème particulier, je ne vois pas bien la nécessité de passer votre temps à les mettre à jour. a moins que vous ne le fassiez par la procédure automatisée des updates Windows ? A priori, là, vous ne risquez pas grand chose effectivement.
Voilà pour quelques conseils pour un avenir plus serein avec votre PC.
maintenant,
Pour vos problemes des BSOD...
Si vous avez écarté les hypothèses matérielles, de chauffe et de mémoire défaillante notamment,
j'aurais bien penché pour une infection, mais je ne sais pas analyser le rapport de "tdsskiller".
Sinon,
malheureusement, je dirais que le systeme est instable parce que vous avez trop "joué" avec le registre.
Installes + desinstalles + maj + nettoyages registre sauvages = pas étonnant que ça beugue !
Je ne suis pas un expert des BSOD, je résous les cas qui se présentent au "coup par coup", c'est juste peu fréquent, heureusement...
Et au vu de ce que j'ai lu dans vos posts, je ne peux vous en dire plus.
Juste, j'aurais commencé par voir en mode sans echec+reseau si le tout est stable.
Vu la fréquence de vos BSOD, ca devrait être assez rapide à voir.
Stresser un peu le PC, lancer qqs applis, une petite video, un ou deux trucs qui scannent le disque, hop, voir.
Du coup, si c'est stable, il est alors possible de rechercher du coté des drivers système.
Sinon, ce que je pense a priori, au vu des fichiers incriminés dans vos crash dumps, votre base de registre est endommagée.
Voire des fichiers système, ce qui ramènerait à l'hypothèse d'une infection ???
Voilà des pistes, bon courage.
Et, au fait, dernière question, peut être pas la plus dénuée d'intéret,
Vous mentionnez, "depuis 2 mois, le nombre de BSOD etc." : à quand remonte la plus lointaine sauvegarde systeme ou registre ?
Peut être la solution en desespoir de cause ???
