Bluescreen intempestif avec Windows 7
bill06
Message par bill06 »
Rapport d'analyse et Conclusion de la part de Whocrashed
Crash Dump Analysis
On Sat 19/03/2011 21:58:19 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031911-24429-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70740)
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFF80002CC9C9C)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This was probably caused by the following module: scmndisp.sys (scmndisp+0x16D1)
file path: C:\Windows\system32\drivers\scmndisp.sys
product: ® Neutral Wireless Solution
company: Windows (R) Codename Longhorn DDK provider
description: NDIS User mode I/O Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: scmndisp.sys (NDIS User mode I/O Driver, Windows (R) Codename Longhorn DDK provider).
Google query: scmndisp.sys Windows (R) Codename Longhorn DDK provider IRQL_NOT_LESS_OR_EQUAL
On Sat 19/03/2011 12:01:44 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031911-34055-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFF80002CDAC9C)
On Fri 11/03/2011 00:11:38 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031111-22635-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFF80002CD7C9C)
On Thu 10/03/2011 23:53:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031111-39015-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFF80002CD8C9C)
Conclusion
5 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
BrunoM45
Re: Bluescreen intempestif avec Windows 7
Message par BrunoM45 »
Salut BIll06
Je m'appelle Christian et j'ai 41 ans. Je viens d'acquérir depuis peu un ordinateur avec Windows 7 et ces derniers temps il plante beaucoup
J'espère trouver sur ce forum une solution à mon problème.
Oui et tu nous laches ton problème comme ça ... :x
Sans autre "mots" de ta part !?
Et bien moi je dis que tu as juste à lire ton message, la potentielle solution ce trouve dedans ;)
Nota : si tu viens de l'acheter pour ne pas aller voir le magasin/la personne qui te l'a vendu !?
Cordi@lement
Tu aurais effectivement pu éviter de lâcher ton problème sans salutations ni explication.
IL semble que ce soit en rapport avec une carte Wi-Fi Netgear.
En disposes-tu d'une sur ton PC.
Il conviendrait de la désinstaller et de la réinstaller.
