MBR Backup - Sauvegarde du Master Boot Record
Un petit utilitaire présenté sur The Windows Club
MBR Backup
What does MBR Backup do?
MBR Backup helps you create a backup of your Master Boot Record. If you ever need to restore it you know you will have a valid copy available. MBR Backup gives you two ways of backing up your MBR - to a file or by printing(!) it. Believe it or not, printing it is actually the best method to back up your MBR, for several reasons:
* With a printout you always have a physical copy of the MBR to hand
* No chance of saving the MBR to a file on the hard drive that gets corrupted
* The MBR is only 512 bytes in size. Typing it in manually will be the least of your concerns if all your data is gone
SYNTAX-ERROR
Re: MBR Backup - Sauvegarde du Master Boot Record
Message par SYNTAX-ERROR »
Si on choisi de l'imprimer,on rentre ce code ou si on a besoin de restaurer le MBR. ?? :bizar:
Dans une invite de commande ?? :oops:
Pierre Desproges
ЅЎЍТΔХ~ΣЯЯФЯ™
Bonjour Syntax,
Je vous livre l'info telle que je l'ai trouvée .... pas encore testé ce MBR Backup.
