Erreur ecran bleu
Posté : mer. 28 juin 2017 01:46
Salut tout le monde
ces dernier jours j'ai une erreur ecran bleu et voici le rapport de whocrashed:
Crash Dump Analysis
On Mon 26/06/2017 20:53:10 your computer crashed
crash dump file: C:\Windows\Minidump\062617-30685-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x15A277)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF91D67277, 0xFFFFFFFF8E6AEDD8, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\DRIVERS\nvlddmkm.sys
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys .
Google query: nvlddmkm.sys KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
On Mon 26/06/2017 15:45:32 your computer crashed
crash dump file: C:\Windows\Minidump\062617-22120-01.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0x1AAC3)
Bugcheck code: 0x24 (0x1904FB, 0xFFFFFFFFA1CABA2C, 0xFFFFFFFFA1CAB610, 0xFFFFFFFF8490F32C)
Error: NTFS_FILE_SYSTEM
file path: C:\Windows\system32\drivers\ntfs.sys
product: Système d’exploitation Microsoft® Windows®
description: Pilote du système de fichiers NT
Bug check description: This indicates a problem occurred in the NTFS file system.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sun 25/06/2017 17:00:36 your computer crashed
crash dump file: C:\Windows\Minidump\062517-20342-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x9F194)
Bugcheck code: 0x1A (0x41790, 0xFFFFFFFFC0802438, 0xFFFF, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules. This problem might also be caused because of overheating (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sun 25/06/2017 04:21:28 your computer crashed
crash dump file: C:\Windows\Minidump\062517-25927-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x92474)
Bugcheck code: 0x4E (0x7, 0x4EDA2, 0x561, 0x0)
Error: PFN_LIST_CORRUPT
Bug check description: This indicates that the page frame number (PFN) list is corrupted.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Fri 23/06/2017 13:40:05 your computer crashed
crash dump file: C:\Windows\Minidump\062317-21169-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x27A9C8)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF84ACC9C8, 0xFFFFFFFF8E68ABBC, 0x0)
Merci d'avance
Crash Dump Analysis
Merci d'avance
