Bluescreen
Posté : jeu. 29 mars 2012 19:06
J'ai formater Hier aprem et depuis j'enchaine les Bluescreen, mais que en jouant en League of Legend et qu'en fin de partie...
On Thu 29/03/2012 15:01:08 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032912-22417-01.dmp
This was probably caused by the following module: dxgmms1.sys (dxgmms1+0x1D6BC)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF9213C6BC, 0xFFFFFFFFAACC3968, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\drivers\dxgmms1.sys
description: DirectX Graphics MMS
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
This was probably caused by the following module: dxgmms1.sys (dxgmms1+0x1DF53)
Bugcheck code: 0x8E (0xFFFFFFFFC0000005, 0xFFFFFFFF9213C6BC, 0xFFFFFFFFAACC3968, 0x0)
Bug check description: This bug check indicates that a kernel-mode application generated an exception that the error handler did not catch.
On Wed 28/03/2012 12:16:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032812-16021-01.dmp
This was probably caused by the following module: klif.sys (klif+0x20019)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF9213C6BC, 0xFFFFFFFFB153F9C4, 0x0)
file path: C:\Windows\system32\drivers\klif.sys
product: Kaspersky™ Anti-Virus ®
company: Kaspersky Lab
description: Klif Mini-Filter [fre_wlh_x86]
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: klif.sys (Klif Mini-Filter [fre_wlh_x86], Kaspersky Lab).
Google query: klif.sys Kaspersky Lab KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
3 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
