bonjour et meilleurs vœux a tous et a toutes
me revoilà sur ce forum pour demander de nouveau de l'aide
depuis une semaine je me coltine de nouveau des blue screen et autre joyeuseté et ce malgré que j'ai refait mon pc en profondeur , fait test en supprimant ram , déplacé et autre ca change rien
impossible de faire recherche de virus approfondie que ce soit avec bit defender ou avast (programme installé chaqu'un leur tour et supprimer complétement a chaque fois pour éviter les conflit bien sur)
sans toucher au pc aucun programme de lancé , il plante tout seul, les températures sont de 36° proc et 41° carte vidéo donc viens pas de la
merci de votre aide
Welcome to WhoCrashed (HOME EDITION) v 3.03
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. If will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit
http://www.resplendence.com/supportClick here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which also allows analysis of crashdumps on remote drives and computers on the network and offers a range of additional features.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: GenuineIntel Pentium(R) Dual-Core CPU E6300 @ 2.80GHz Intel586, level: 6
2 logical processors, active mask: 3
RAM: 3488931840 total
VM: 2147352576, free: 1866412032
Crash Dump Analysis
On Sun 08/01/2012 12:56:59 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010812-13687-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x705C0)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF800028AAA4F, 0x0, 0xFFFFFFFFFFFFFFFF)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Sun 08/01/2012 12:31:47 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010812-14593-01.dmp
Bugcheck code: 0x1A (0x41287, 0x0, 0x0, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Sun 08/01/2012 12:30:31 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010812-22906-01.dmp
Bugcheck code: 0x50 (0xFFFFFFFFFFFFFFF5, 0x0, 0xFFFFF80002BA83ED, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
On Sun 08/01/2012 11:40:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010812-13156-01.dmp
Bugcheck code: 0x4E (0x9A, 0x8593D, 0x2, 0x0)
Error: PFN_LIST_CORRUPT
Bug check description: This indicates that the page frame number (PFN) list is corrupted.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Sun 08/01/2012 11:15:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010812-15031-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7FBC6)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF800028DEBC6, 0xFFFFF88002FFF848, 0xFFFFF88002FFF0B0)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
On Sat 07/01/2012 19:33:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010712-21953-01.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0x5B68)
Bugcheck code: 0x24 (0x1904FB, 0xFFFFF88002FAB1C8, 0xFFFFF88002FAAA30, 0xFFFFF88001250A38)
Error: NTFS_FILE_SYSTEM
file path: C:\Windows\system32\drivers\ntfs.sys
description: Pilote du système de fichiers NT
Bug check description: This indicates a problem occurred in the NTFS file system.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Sat 07/01/2012 19:02:40 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010712-21296-01.dmp
Bugcheck code: 0x24 (0x1904FB, 0xFFFFF88001E3C4E8, 0xFFFFF88001E3BD50, 0x40170289C874)
On Sat 07/01/2012 18:10:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010712-12843-01.dmp
Bugcheck code: 0x1A (0x403, 0xFFFFF6800000A560, 0x3C8000001CA90867, 0xFF00F6800000C16A)
On Sat 07/01/2012 16:36:34 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010712-16484-01.dmp
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8001822380, 0xFFFF, 0x0)
On Sat 07/01/2012 15:59:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010712-15718-01.dmp
Bugcheck code: 0x4E (0x99, 0x33E81, 0x5, 0x1)
On Sat 07/01/2012 15:51:06 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010712-17296-01.dmp
Bugcheck code: 0x1A (0x61940, 0xFFFFF98035F12000, 0x0, 0x0)
On Sat 07/01/2012 11:25:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010712-31812-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70590)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
On Sat 07/01/2012 11:22:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010712-26062-01.dmp
Bugcheck code: 0x19 (0x3, 0xFFFFF80002A06BE0, 0x54004E00000008, 0xFFFFF80002A06BE0)
Error: BAD_POOL_HEADER
Bug check description: This indicates that a pool header is corrupt.
On Sat 07/01/2012 07:54:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010712-18390-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x71F00)
Bugcheck code: 0xA (0x1ABCFF96, 0x2, 0x1, 0xFFFFF8000287D4D8)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
Conclusion
20 crash dumps have been found and analyzed. Only 15 are included in this report.
