Ecran bleu à repétition : Memory management [Résolu]cf.page5
Re: Ecran bleu à repétition : Memory management [Résolu]
Messagede 14niepce » Sam 10 Avr 2010 14:21
Bonjour Roballar,
J'ai crée un post pour cette discussion : #p30817
Intel Q8200 (2,33 GHz), 4Go Ram, SSD 64Go, Nvidia 9400GT 512Mo
Windows 7 (32bits) et Ubuntu 9.10
14niepce
Messagede roballar » Sam 10 Avr 2010 14:54
Bonne idée, je viens de te répondre. ;)
roballar
Re: Ecran bleu à repétition : Memory management [Résolu]cf.page5
Messagede Chicken In Fire » Mar 4 Oct 2011 20:15
Bien que ce topic date d'un an, j'espère avoir une réponse...
Mon problème est le même que celui posé au départ. J'ai l'impression que les Blue Screens sont de plus en plus fréquent :(
Voici mon rapport WhoCrashed :
On Tue 10/4/2011 5:55:34 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\100411-17409-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC40)
Bugcheck code: 0x1A (0x5003, 0xFFFFF70001080000, 0x6996, 0x2831009)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Fri 9/30/2011 12:02:14 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\093011-13603-01.dmp
Bugcheck code: 0x18 (0xFFFFFA8003572570, 0xFFFFFA8003A88A80, 0x1, 0x1)
Error: REFERENCE_BY_POINTER
Bug check description: This indicates that the reference count of an object is illegal for the current state of the object.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Thu 9/29/2011 3:55:43 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\092911-19874-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF800032540D9, 0xFFFFF880086F1040, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
On Tue 9/27/2011 1:05:55 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\092711-21684-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC10)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
Merci d'avance ! ;)
Chicken In Fire
Messagede 14niepce » Mar 4 Oct 2011 21:51
Pour rappel, mon problème a été résolu avec des nouvelles barrettes mémoire, pas plus compliqué que cela !
Ce n'est toujours pas évident pour tester (sauf si tu as des barrettes compatibles avec ton système en stock).
Mais j'ai perdu énormément de temps sur le temps à tenter de trouver une réponse. J'ai aussi installé plusieurs softs afin de tester l'ordinateur...
Bref,si tu veux un conseil, apporte ton PC dans un magasin (à Paris quartier mongalet ou même surcouf) et demande de réaliser un test avec des nouvelles barrettes.
Sinon, je ne connais pas de solution miracle.
Bon courage
14niepce
Messagede Chicken In Fire » Mer 5 Oct 2011 15:28
J'ai viré les derniers trucs installés sur mon pc pour voir si ça faisait une différence, pour l'instant pas d'écran bleu de la mort. Je suivrais ton conseil si ça recommence.
Je vous tiens au courant, et merci pour le conseil ! :)
Chicken In Fire
Messagede stephe12 » Mer 29 Fév 2012 12:12
j'ai moi aussi pas mal de problèmes de ce genre depuis quelques semaines.
J'ai un pc dell qui etait sous garantie. Il y a un mois, ecran bleu à repetition (parfois une dizaine) au demarrage de l'ordo mais une fois qu'il avait démarré, il marchait très bien jusqu'à la fin de la journée. Les problèmes qui reviennaient souvent etaient "memory management" et "system service exeption".
J'ai appelé Dell qui m'a conseillé un formatage complet ce qui a été fait. Au depart, après le formatage, tout allait très bien, plus aucun ecran bleu. Ma garantie arrive à terme et là, depuis 2 jours, les ecrans bleus reviennent avec les mêmes problèmes.
Du coup, je n'ai plus de garantie et les problèmes reviennent ...
J'ai un krach qui est celui ci :
On Wed 29/02/2012 08:56:48 GMT your computer crashed
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF9600025E4C4, 0xFFFFF880028B0880, 0x0)
Quelqu'un a t'il une idée ??
stephe12
Messagede 14niepce » Mer 29 Fév 2012 12:18
Bonjour Steph12,
Si tu lis mes posts, tu verras que mon arodi avait un comportement très similaire au tien.
Ma solution a été le remplacement des barrettes mémoire.
Cordialement,
14niepce
Messagede stephe12 » Mer 29 Fév 2012 12:41
ok, je vais essayer cela et je vous tiens informé.
stephe12
Messagede stephe12 » Mer 29 Fév 2012 12:44
juste une chose : comment savoir quelles barrettes mettre pour remplacer les miennes ??
stephe12
Messagede 14niepce » Mer 29 Fév 2012 12:46
tu peux regarder la confirguration de ta machine, contacter le fabricant ou installer ma-config (http://www.ma-config.com/)
14niepce
PrécédenteSuivante
Retourner vers Matériels
