Crash PC
Crash PC
Messagepar sylcarp » Jeu 31 Mai 2018 19:14
Voila mon PC crash depuis plusieurs, alors si quelqu un pouvais m eclairer sur le probleme ca serait cool .
voila un copier coller de Whocrashed
Computer name: SKDESIGN-PC
Windows version: Windows 7 Service Pack 1, 6.1, build: 7601
Windows dir: C:\Windows
Hardware: MS-7917, MSI, Z97 GAMING 5 (MS-7917)
CPU: GenuineIntel Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 17125998592 bytes total
Crash Dump Analysis
Crash dumps are enabled on your computer. This system is not configured for complete or automatic crash dumps. For best results, configure your system to write out complete or automatic crash dumps. Select Tools->Crash Dump Configuration from the main menu to configure your system to write out complete memory dumps.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Thu 31/05/2018 18:58:35 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\053118-6333-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC40)
Bugcheck code: 0x7A (0xFFFFF6FC40008BD0, 0xFFFFFFFFC000000E, 0x38806D860, 0xFFFFF8800117A880)
Error: KERNEL_DATA_INPAGE_ERROR
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!wcsncat_s+0x1F73A)
On Wed 30/05/2018 22:09:48 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\053018-3931-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800F21CB30, 0xFFFFFA800F21CE10, 0xFFFFF800033948B0)
Error: CRITICAL_OBJECT_TERMINATION
Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated. This bug check is typically caused by a thermal issue. It's suggested that you do temperature checking on your CPUs and hardware.
This is likely to be caused by a hardware problem. This problem might also be caused because of overheating (thermal issue).
On Wed 30/05/2018 22:03:14 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\053018-5350-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800CFC5830, 0xFFFFFA800CFC5B10, 0xFFFFF800033D38B0)
On Wed 30/05/2018 21:59:25 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\053018-5241-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800EFE4B30, 0xFFFFFA800EFE4E10, 0xFFFFF800033878B0)
On Tue 29/05/2018 17:38:45 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\052918-5616-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800EF85B30, 0xFFFFFA800EF85E10, 0xFFFFF800033988B0)
On Mon 28/05/2018 02:28:18 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\052818-5350-01.dmp
Bugcheck code: 0x7A (0xFFFFF6FB40000150, 0xFFFFFFFFC000000E, 0x300ADB884, 0xFFFFF6800002A000)
On Mon 14/05/2018 17:58:59 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\051418-5241-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800EFE9B30, 0xFFFFFA800EFE9E10, 0xFFFFF800033828B0)
On Sun 22/04/2018 18:03:43 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\042218-5428-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFFA800CA14060, 0xFFFFF800038073D8, 0xFFFFFA8010C10010)
Error: DRIVER_POWER_STATE_FAILURE
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state. A device object has been blocking an IRP for too long a time.
On Fri 19/08/2016 15:44:57 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\081916-4945-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFFA800C9F4A10, 0xFFFFF800038073D8, 0xFFFFFA800CE946E0)
Conclusion
10 crash dumps have been found and analyzed. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
sylcarp
Re: Crash PC
Messagepar PatriciaG » Ven 1 Juin 2018 01:32
Cela ressemble à un problème de carte graphique.
As-tu une CG Nvidia, quel modèle.
Utilises-tu Nvidia GeForce Experience ?
Effectue une détection automatique des pilotes sur TousLesDrivers.com, onglet MES DRIVERS
http://www.touslesdrivers.com/
Fais les mises à jour requises, ensuite redémarre le PC après ces maj, puis effectue une nouvelle détection sur TLD et poste-moi le lien (pas les copies d’écran) du nouveau rapport de détection.
Si tu possèdes bien une carte graphique Nvidia, effectue en plus la procédure suivante.
Télécharge et installe Display Driver Uninstaller (DDU)
https://www.guru3d.com/files-details/di ... nload.html
Ouvre une session en mode sans échec
http://www.chantal11.com/2010/05/demarr ... ans-echec/
Exécute DDU, sélectionne NVIDIA.
A la fin de l'exécution de DDU, redémarre le pc.
Ouvre une session Windows en mode normal.
Ensuite, télécharge le pilote de ta carte graphique via le lien le plus récent indiqué par TLD.
Dans le programme d'installation NVIDIA, sélectionne "Installation personnalisée (Avancé)", coche "Pilote graphique" et "PhysX" (pour les jeux vidéo) et ne coche pas "NVIDIA GeForce Experience".
Coche "Nouvelle installation" pour effectuer une installation propre après suppression de l’ancien profil.
Ne (ré)installe pas Nvidia GeForce Experience, source de bugs multiples.
Re: Crash PC
Messagepar sylcarp » Ven 1 Juin 2018 16:41
merci deja pour tes reponse je vais essayer ca
sylcarp
Re: Crash PC
Messagepar PatriciaG » Ven 1 Juin 2018 23:25
Pense à indiquer si tu possèdes une CG Nvidia ni indiqué et si tu utilises Nvidia GeForce Experience.
Bonnes réparations.
Retourner vers Matériels
