Erreur ecran bleu
Erreur ecran bleu
Messagepar parker » Mer 28 Juin 2017 01:46
Salut tout le monde
ces dernier jours j'ai une erreur ecran bleu et voici le rapport de whocrashed:
Crash Dump Analysis
On Mon 26/06/2017 20:53:10 your computer crashed
crash dump file: C:\Windows\Minidump\062617-30685-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x15A277)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF91D67277, 0xFFFFFFFF8E6AEDD8, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\DRIVERS\nvlddmkm.sys
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys .
Google query: nvlddmkm.sys KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
On Mon 26/06/2017 15:45:32 your computer crashed
crash dump file: C:\Windows\Minidump\062617-22120-01.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0x1AAC3)
Bugcheck code: 0x24 (0x1904FB, 0xFFFFFFFFA1CABA2C, 0xFFFFFFFFA1CAB610, 0xFFFFFFFF8490F32C)
Error: NTFS_FILE_SYSTEM
file path: C:\Windows\system32\drivers\ntfs.sys
description: Pilote du système de fichiers NT
Bug check description: This indicates a problem occurred in the NTFS file system.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sun 25/06/2017 17:00:36 your computer crashed
crash dump file: C:\Windows\Minidump\062517-20342-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x9F194)
Bugcheck code: 0x1A (0x41790, 0xFFFFFFFFC0802438, 0xFFFF, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules. This problem might also be caused because of overheating (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sun 25/06/2017 04:21:28 your computer crashed
crash dump file: C:\Windows\Minidump\062517-25927-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x92474)
Bugcheck code: 0x4E (0x7, 0x4EDA2, 0x561, 0x0)
Error: PFN_LIST_CORRUPT
Bug check description: This indicates that the page frame number (PFN) list is corrupted.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Fri 23/06/2017 13:40:05 your computer crashed
crash dump file: C:\Windows\Minidump\062317-21169-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x27A9C8)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF84ACC9C8, 0xFFFFFFFF8E68ABBC, 0x0)
Merci d'avance
parker
Re: Erreur ecran bleu
Messagepar mwonex » Mer 28 Juin 2017 14:12
Problème de pilotes sans doute (d'affichage et plus), essaie ça:
http://www.commentcamarche.net/faq/26313-plantage-de-nvlddmkm-sys-la-solution
lire aussi:
http://www.commentcamarche.net/forum/affich-15076501-nvlddmkm-sys-nvidia-enfin-la-solution
Un sfc /scannow pourrait être utile -(en ligne de commande)
Messagepar jjcojax » Mer 28 Juin 2017 21:30
Comme les "blue screen" font des dégâts dans le système de fichier ...
Je me permet d'ajouter qu'il serait bon de faire un chkdsk c: /f (via cmd en mode admin) pour nettoyer le système (/f = fix)
-> comme Windows est actif, on te proposera de le faire au prochain démarrage.
Pour la suite mwonex que je salue au passage sera bien plus réactif que moi ;)
Messagepar mwonex » Jeu 29 Juin 2017 16:30
Non, non jjcojax, le but c'est d'être efficace, et tu as raison un check disk est bienvenu un salut également ;)
Voir aussi ce sujet exhaustif avec les solutions d'ordre général en bas pour ne pas se lasser:
https://lecrabeinfo.net/guide-ultime-pour-resoudre-erreurs-probleme-ecran-bleu-bsod-sur-windows.html
Messagepar txuku » Ven 30 Juin 2017 10:50
Mwonex ton lien est interessant !
C est vrai que l on rencontre souvent ntoskrnel.exe dans les minidump et j ai voulu tester Winsdk ( le kit SDK ) et j ai eu des problemes avec Net Framework 4................... - deja installe - pas le bon - etc... )
Messagepar PatriciaG » Sam 1 Juil 2017 00:06
Outre le tutoriel du Crabe très complet, que je connaissais, voici deux autres tutoriels utiles, mais en anglais
Rés;oudre les écrans bleus dans Windows 10/8.1/8/7
http://www.thewindowsclub.com/windows-7 ... eens-guide
Trouver les BSOD et les résoudre
https://answers.microsoft.com/en-us/win ... 5ee5d8669d
Messagepar mwonex » Sam 1 Juil 2017 12:12
"txuku a dit:
Normalement ça devrait avec le Net framework 4 ?
Je n'ai plus WIndows 7, on m'en vendrai un portable à 200 €, donné!
Retourner vers Matériels
