[Info] Nouvelle version Malwarebytes 3
Messagepar chantal11 » Sam 10 Déc 2016 11:51
Une nouvelle version Malwarebytes 3.0 est disponible.
Lien de téléchargement de la version actuelle -> mb3-setup-consumer-3.0.4.1269.exe
MALWAREBYTES 3.0 : Plus fort, plus intelligent Rend les antivirus obsolètes
Quatre couches de protection contre les malwares. Une détection plus intelligente. Une protection spécialement conçue contre les ransomwares. C'est la sécurité que vous recherchiez.
https://fr.malwarebytes.com/
L'annonce sur le Blog Malwarebytes
https://blog.malwarebytes.com/malwareby ... placement/
Malwarebytes 3.0.4.1269
Performance / Protective Capability:
• Added signature-less anti-exploit and anti-ransomware protection (Premium only)
• Up to 4x faster scan speeds, including even quicker Hyper Scans
• Removed non-essential reboots after certain malware removal events
• Advanced Heuristic Engine (Shuriken) now enabled by default
• Self-Protection now enabled by default (Premium only)
Usability:
• Redesigned user interface for improved usability
• Now configurable to integrate with Windows Action Center / Windows Security Center (Premium only)
• Update checks are done automatically so they do not need to be scheduled
• Improved support for keyboard navigation and screen readers
Stability / Issues Fixed:
• Added ability to lock down My Account screen via User Access Policy
• Added ability to collect enhanced logs when directed to do so by Support
• Fixed issue where Scheduler did not adjust for Daylight Saving Time changes
• Fixed issue where Scheduler defaulted to hourly Threat Scan instead of Daily
• Fixed issue where Chameleon reported error messages numerous times to Windows Event Viewer
• Changed 'Recover if missed by' setting in Scheduler to Off by default
• Prevented rootkit scanning in Custom Scans if full system drive is not selected
• Updated to latest version of 7-Zip DLL
• Addressed many other miscellaneous defects
Patch du 20/12/2016 -> Malwarebytes 3.0.5.1299
] This release resolves a number of items that have been reported since the initial launch of Malwarebytes 3.0:
Fixed installer error that displayed 'External exception E06D7363'
Fixed issue where updates would get stuck in 'Checking' state
Fixed issue where “Real-Time Protection disabled” notifications would display throughout the day (NOTE: this notification may still be seen on reboot on some systems, but we’re working on another longer-term fix to address that separately)
Fixed slow shutdown issue that could occur in Windows 7 with real-time Malware Protection enabled (NOTE: a corresponding fix for Ransomware Protection is still pending)
Fixed conflict with Kaspersky that would not allow browsers to open properly
Improved upgrade experience when installing over a previous version of the Malwarebytes anti-exploit technology
Re: [Info] Nouvelle version Malwarebytes 3.0
Messagepar pierrevg » Sam 10 Déc 2016 12:35
Comme pour la v2 elle dispose d'une version gratuite ?
pierrevg
Messagepar chantal11 » Sam 10 Déc 2016 14:39
Oui, bien sûr, Malwarebytes, quelque soit la version existe toujours en version gratuite.
La version Premium est en essai gratuit pendant 14 jours avec donc la protection en temps réel, les analyses et mises à jour automatiques et le blocage des sites Web.
Ensuite, si l'utilisateur ne veut pas payer pour la version Premium, Malwarebytes bascule automatiquement en version gratuite.
Les différences entre la version Premium et la version gratuite :
https://fr.malwarebytes.com/trial/#trial
Messagepar pierrevg » Sam 10 Déc 2016 14:44
Super ;)
Et la question débile que je ne dois pas être seul à me poser (méthode Coué, toussa) :
Faut-il que je vide la quarantaine puis désinstalle l'éventuelle ancienne version avant d'installer la nouvelle ?
Merci ;)
pierrevg
Messagepar chantal11 » Sam 10 Déc 2016 14:49
L'assistant d'installation de la nouvelle version 3.0 se charge de tout.
Tu n'as rien à faire normalement, juste exécuter le setup de la nouvelle version par clic-droit -> Exécuter en tant qu'admnistrateur.
Messagepar chantal11 » Mar 20 Déc 2016 10:03
Malwarebytes 3.0.5 Patch Release
La mise à niveau vers 3.0.5 sera proposée automatiquement courant de semaine prochaine.
Pour installer cette dernière version immédiatement sans attendre la mise à niveau, télécharger directement la version 3.0.5.1299
mb3-setup-consumer-3.0.5.1299.exe
https://forums.malwarebytes.com/topic/1 ... available/
Messagepar pierrevg » Mar 20 Déc 2016 12:56
Espérons que la désinstallation sera plus efficace.
Je suis passé de la v2 à la v3 en laissant la v3 se charger de la désinstallation de la v2. Puis, comme la v3 plantait bien régulièrement, j'ai désinstallé la v3 via Programmes et fonctionnalités et je pensais que tout avait été désinstallé. Que nenni, plein de processus sont encore demandés dans les services de windows ;(
Bref... je me demande bien comment désinstaller proprement et efficacement ce truc.
Une idée ?
pierrevg
Messagepar PatriciaG » Mar 20 Déc 2016 13:01
Essaie avec Revo Uninstaller version gratuite, http://www.revouninstaller.com/revo_uni ... nload.html
Messagepar chantal11 » Mar 20 Déc 2016 13:08
Non, Malwarebytes a aussi son outil spécifique pour désinstaller complètement :
  • Télécharge mbam-clean.exe et enregistre-le sur ton Bureau
  • Ferme toutes les applications, y compris ton navigateur et désactive temporairement ton antivirus
  • Double-clique sur l'icône mbam-clean.exe pour lancer l'application
  • Suis les instructions de l'outil
  • Un redémarrage est demandé, il est important de valider et laisser redémarrer le système (redémarrer manuellement au besoin)
Messagepar pierrevg » Mer 21 Déc 2016 02:07
Manip effectuée et il reste des tas d'occurrences à mbam dans le registre...
C'est pas pour faire mon pénible mais est-ce normal ?
pierrevg
Suivante
