ecran de la mort
Re: ecran de la mort
Messagepar nardino » Mer 23 Oct 2013 15:36
Image WhoCrashed Home Edition 4.01 de Resplendence
Tu l'installes et tu le lances par Analyze.
Image Tu postes un copier-coller de ce qui apparait .
Le rapport LOCALT~11.html sera dans le dossier du programme WhoCrashed.
Messagepar seventator » Jeu 24 Oct 2013 08:09
le rapport
System Information (local)
computer name: TONY-HP
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\windows
CPU: GenuineIntel Intel(R) Core(TM) i3-2310M CPU @ 2.10GHz Intel586, level: 6
2 logical processors, active mask: 3
RAM: 4226138112 total
VM: 2147352576, free: 1929625600
Crash Dump Analysis
Crash dump directory: C:\windows\Minidump
No valid crash dumps have been found on your computer
Conclusion
Crash dumps are enabled but no valid crash dumps have been found. It may be that there are problems which prevent crash dumps from being written out. Check out the following article for possible causes: If crash dumps are not written out.
In case your computer does experience sudden reboots it is likely these are caused by malfunctioning hardware, power failure or a thermal issue. To troubleshoot a thermal issue, check the temperature using your BIOS setup program, check for dust in CPU and motherboard fans and if your computer is portable make sure it's located on a hard surface. Otherwise it's suggested you contact the support department of the manufacturer of your system or test your system with a memory test utility for further investigation.
Check out the following articles for more information: Troubleshooting sudden resets and shut downs.
seventator
Messagepar nardino » Jeu 24 Oct 2013 12:08
As-tu encore des problèmes ?
Messagepar seventator » Jeu 24 Oct 2013 13:41
Bonjour Nardino,
oui j'ai encore les mêmes problèmes, je vais sur le net, j'ai une page de démarrage orange
et quand je veux ouvrir un favori enregistré celui -ci ne s'ouvre pas, aussi quand j'ouvre plusieurs fenêtres, mon écran bleu arrive...
Par contre sur la page google je n'ai pas ses soucis...
Voilà j'espère avoir été à peu près clair.
Je te remercie encore Nardino pour le temps que tu veux bien m'accorder. :super:
à @
Tony
seventator
Messagepar nardino » Jeu 24 Oct 2013 13:45
Dans les options Internet, onglet Avancé, tu cliques sur le bouton Réinitialiser.
Messagepar seventator » Jeu 24 Oct 2013 17:12
donc j'ai fait, je suis retourné sur ma page mail, j'ai ouvert un mail mensuel de facture, demande de facture internet, format PDF on me demande si je veux utiliser le programme Soda PDF5, je valide et là écran bleu encore...
seventator
Messagepar nardino » Jeu 24 Oct 2013 17:22
Je ne connais pas ce programme Soda PDF5.
Mais tu peux aisément le remplacer par Foxit Reader qui lui n'est pas vérolé.
Messagepar seventator » Jeu 24 Oct 2013 20:39
Je viens de le supprimer mais cela n'a pas arrêter le crash cela a recommencé après...
à @
Tony
seventator
Messagepar nardino » Jeu 24 Oct 2013 22:07
Fais une analyse avec cet antivirus :
Image CureIt Dr.Web
Il ne nécessite pas d'installation.
Image Lance le fichier launch.exe après avoir désactivé ton antivirus résident.
Il va te demander de faire la mise à jour
Une fois celle-ci effectuée, il va lancer un scan rapide.
Quand tout ceci est terminé, tu choisis scan sélectif et tu coches au moins C qui contient le système.
Image A la fin du scan, tu mets tout en quarantaine et tu postes le rapport.
Comme il sera assez conséquent, héberge-le sur Cjoint comme indiqué sur ce tutoriel
Messagepar seventator » Lun 28 Oct 2013 14:57
Bonjour Nardino,
Bon je n'ai aucun rapport après le scan.
J'espère avoir fait tout correctement.
J'ai toujours le même soucis.
à @
Tony
seventator
PrécédenteSuivante
