Plantage Battlefield Bad Compagny 3
Performances, bugs, ...
Messagepar sandosan » Mar 26 Mar 2013 23:45
bonjour chez moi il se passe ce qui suit.
le soucis, c'est que j'ai déjà mes drivers à jour et le probleme persiste..
quelqu'un aurait une ide s'il vous plait.?
ça fait un bon moment que je suis penché dessus.
avant j'avais une ati HD 4870 et 'javais déjà le meme probleme.
ça me le fait qu'avec BF3...
Welcome to WhoCrashed (HOME EDITION) v 4.01
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. It will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit www.resplendence.com/support
Click here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which also allows analysis of crashdumps on remote drives and computers on the network and offers a range of additional features.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
computer name: SANDRO-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz Intel586, level: 6
RAM: 8588935168 total
VM: 2147352576, free: 1952432128
Crash Dump Analysis
On Tue 26/03/2013 21:15:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032613-32573-01.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF8800520C83E)
Bugcheck code: 0xD1 (0xFFFFFA804552CC02, 0xB, 0x0, 0xFFFFF8800520C83E)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 314.07
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 314.07
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 314.07 , NVIDIA Corporation).
Google query: NVIDIA Corporation DRIVER_IRQL_NOT_LESS_OR_EQUAL
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x1E183E)
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
sandosan
Re: Plantage Battlefield Bad Compagny 3
Messagepar grimpeur » Jeu 28 Mar 2013 14:58
sandosan a écrit:avant j'avais une ati HD 4870 et j'avais déjà le même problème.
Et quelle est la marque et la référence de ta nouvelle carte nvidia puisque tu n'as rien mentionné à ce sujet :?:
Configuration minimale :Non officielle
- Windows XP/Vista/7
- Processeur Dual Core 2.0 Ghz
- 2 Go de mémoire
- Carte graphique 256 Mo, DirectX 10, shader model 4.0, ATI Radeon 3870 ou GeForce 8800 GT.
- Espace disque : 15 Go pour la version téléchargée, 10 Go pour la version DVD.
Configuration recommandée :Non officielle
- Windows Vista / 7
- Processeur Dual Core ou Quad Core 2.6 GHz
- 2 Go de mémoire pour Windows 32 bits et 4 Go pour Windows 64 bits.
- Carte graphique 512 Mo, shader model 5.0, DirectX 11. Geforce GTS 450 ou Radeon HD 5770 minimum.
Cartes graphiques recommandées pour jouer dans de bonnes conditions:
(Classées par ordre de performance)
Séries NVIDIA GeForce: 9800 GTX, GTS 250, GTS 450, GTX 550, GTX 260 et +..., GTX 465, GTX 460 et +..., 560 et +...
Séries ATI Radeon: HD 5750, HD 6750, HD 4850, HD 4770, HD 4870, HD 5770, HD 6770, HD 5830, HD 4890, HD 6790, HD 6850, HD 5850, HD 6870, HD 5870, HD 6950, HD 6970 et +..., HD 5970 et +...
Pour les PC portable, voici une liste de cartes graphiques (mobile) par ordre de performances. Les cartes graphiques qui se situent dans le tableau de couleur vert pourront faire tourner BF3. Les cartes situées dans le tableau verdâtre jusqu' à la 100 eme position, pourront jouer avec les options "Moyen-bas".
Pour l' achat d' un PC portable gamer, RDV ici: Les PC portables jeux 2012
Tout ceci est approximatif.
Edition au 20 Septembre 2011.
CONFIGURATION MINIMALE REQUISE OFFICIELLE
WINDOWS VISTA (SERVICE PACK 2) 32 BITS
PROCESSEUR: 2 GHZ DOUBLE COEUR (CORE 2 DUO 2,4 GHZ OU ATHLON X2 2.7 GHZ)
MÉMOIRE: 2 GO
DISQUE DUR: 20 GO
CARTE GRAPHIQUE (AMD): DIRECTX 10.1 COMPATIBLE AVEC 512 MO DE RAM (ATI RADEON 3000, 4000, 5000 OU 6000 SERIES, AVEC ATI RADEON 3870 OU SUPÉRIEURE)
CARTE GRAPHIQUE (NVIDIA): COMPATIBLE DIRECTX 10.0 AVEC 512 MO DE RAM (NVIDIA GEFORCE 8, 9, 200, 300, 400 OU SÉRIE 500 AVEC NVIDIA GEFORCE 8800 GT OU SUPÉRIEURE)
CONFIGURATION RECOMMANDÉE OFFICIELLE
WINDOWS 7 64-BIT
PROCESSEUR: QUAD-CORE 2,6 GHZ
MÉMOIRE: 4 GO
DISQUE DUR: 20 GO
CARTE GRAPHIQUE: COMPATIBLE DIRECTX 11 AVEC 1024 MO DE RAM (NVIDIA GEFORCE GTX 560 OU ATI RADEON 6950)
:fleche2: La source
Messagepar nardino » Ven 29 Mar 2013 14:57
Commence par une mise à jour de ta carte graphique sur le site Nvidia.
http://www.nvidia.fr/Download/index.aspx?lang=fr
Messagepar sandosan » Jeu 20 Juin 2013 18:56
ma carte graphique
gainward GFORCE GTX570
les mises à jour sont déjà faites....
merci de lire le post avant de répondre sans réfléchir......
sandosan
Messagepar nardino » Jeu 20 Juin 2013 19:27
Va te faire foutre.
Messagepar Oupsy » Mar 25 Juin 2013 16:53
J'avais bien une réponse à ton problème mais vu ton amabilité , je préfère m'abstenir au lieu de me faire envoyer balader.
Bon vent
Oupsy
Messagepar aimerzuo » Mer 30 Oct 2013 09:55
Merci de ces infos , très utiles et vraiment détaillées
aimerzuo
Retourner vers Jeux vidéo
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 6 invités
