de Drezling » Lun 16 Juil 2012 12:27
Je crois que c'est ça ce que tu me demande, si je comprends ce qui se passe c'est Avast le problème ? :
Crash Dump Analysis
On Sun 15/07/2012 16:13:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071512-19234-01.dmp
This was probably caused by the following module: aswsnx.sys (aswSnx+0x162C8)
Bugcheck code: 0x7A (0xFFFFFFFFC0501830, 0xFFFFFFFFC0000185, 0x340D88C0, 0xFFFFFFFFA0306000)
Error: KERNEL_DATA_INPAGE_ERROR
file path: C:\Windows\system32\drivers\aswsnx.sys
product: avast! Antivirus System
company: AVAST Software
description: avast! Virtualization Driver
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: aswsnx.sys (avast! Virtualization Driver, AVAST Software).
Google query: aswsnx.sys AVAST Software KERNEL_DATA_INPAGE_ERROR
On Sun 15/07/2012 14:09:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071512-16021-01.dmp
This was probably caused by the following module: classpnp.sys (CLASSPNP+0x5164)
Bugcheck code: 0xA (0x34, 0x2, 0x1, 0xFFFFFFFF83084A8F)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\classpnp.sys
description: SCSI Class System Dll
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Sat 14/07/2012 21:07:19 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071412-15319-01.dmp
This was probably caused by the following module: win32k.sys (win32k+0xCF7B7)
Bugcheck code: 0x7A (0xFFFFFFFFC07FA028, 0xFFFFFFFFC0000185, 0xFFFFFFFF8A7088C0, 0xFFFFFFFFFF405EB4)
file path: C:\Windows\system32\win32k.sys
description: Pilote Win32 multi-utilisateurs
On Sat 14/07/2012 19:53:17 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071412-15428-01.dmp
This was probably caused by the following module: aswsnx.sys (aswSnx+0x8D24)
Bugcheck code: 0x19 (0x3, 0xFFFFFFFF8318B818, 0x0, 0xFFFFFFFF8318B818)
Error: BAD_POOL_HEADER
Bug check description: This indicates that a pool header is corrupt.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
Google query: aswsnx.sys AVAST Software BAD_POOL_HEADER
On Sat 14/07/2012 10:45:11 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071412-17815-01.dmp
Bugcheck code: 0xA (0x47800034, 0x2, 0x1, 0xFFFFFFFF830B4A8F)
On Sat 14/07/2012 08:56:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071412-15740-01.dmp
Bugcheck code: 0xA (0x47800034, 0x2, 0x1, 0xFFFFFFFF830BCA8F)
On Fri 13/07/2012 09:10:07 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071312-21637-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0xDEE9C)
Bugcheck code: 0x7A (0xFFFFFFFFC0572F90, 0xFFFFFFFFC0000185, 0x6F2E98C0, 0xFFFFFFFFAE5F201C)
file path: C:\Windows\system32\ntkrnlpa.exe
On Thu 12/07/2012 22:35:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071312-18205-01.dmp
Bugcheck code: 0x7A (0xFFFFFFFFC04521C0, 0xFFFFFFFFC0000185, 0xAF148C0, 0xFFFFFFFF8A4387B4)
On Thu 12/07/2012 12:29:52 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071212-17752-01.dmp
Bugcheck code: 0x7A (0xFFFFFFFFC04D07D8, 0xFFFFFFFFC0000185, 0x5A9ED8C0, 0xFFFFFFFF9A0FBE80)
On Thu 12/07/2012 10:02:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071212-18298-01.dmp
This was probably caused by the following module: ataport.sys (ataport+0x1485E)
Bugcheck code: 0x7A (0xFFFFFFFFC04A2988, 0xFFFFFFFFC0000185, 0x55C508C0, 0xFFFFFFFF94531568)
file path: C:\Windows\system32\drivers\ataport.sys
description: ATAPI Driver Extension
On Thu 12/07/2012 08:59:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071212-18626-01.dmp
This was probably caused by the following module: aswsnx.sys (aswSnx+0x17511)
Bugcheck code: 0xF4 (0x3, 0xFFFFFFFF875BB970, 0xFFFFFFFF875BBADC, 0xFFFFFFFF83262DF0)
Error: CRITICAL_OBJECT_TERMINATION
Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated.
Google query: aswsnx.sys AVAST Software CRITICAL_OBJECT_TERMINATION
On Wed 11/07/2012 14:08:21 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071112-23025-01.dmp
Bugcheck code: 0x7A (0xFFFFFFFFC0466858, 0xFFFFFFFFC0000185, 0x48F0EBE0, 0xFFFFFFFF8CD0B000)
On Tue 10/07/2012 19:10:07 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071012-26223-01.dmp
Bugcheck code: 0x7A (0xFFFFFFFFC0416060, 0xFFFFFFFFC0000185, 0xFFFFFFFF83F448C0, 0xFFFFFFFF82C0C000)
Conclusion
13 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
