[Résolu] Sablier de la souris qui tourne indéfiniment
Re: Sablier de la souris qui tourne indéfiniment
Messagepar kaiy » Jeu 10 Mai 2012 19:14
Voilà le Rapport RogueKiller :
RogueKiller V7.4.4 [08/05/2012] par Tigzy
mail: tigzyRK<at>gmail<dot>com
Remontees: http://www.sur-la-toile.com/discussion- ... ntees.html
Blog: http://tigzyrk.blogspot.com
Systeme d'exploitation: Windows 7 (6.1.7601 Service Pack 1) 64 bits version
Demarrage : Mode normal
Utilisateur: Maël [Droits d'admin]
Mode: Suppression -- Date: 10/05/2012 19:13:36
¤¤¤ Processus malicieux: 1 ¤¤¤
[SUSP PATH] SpotifyWebHelper.exe -- C:\Users\Maël\AppData\Roaming\Spotify\Data\SpotifyWebHelper.exe -> KILLED [TermProc]
¤¤¤ Entrees de registre: 5 ¤¤¤
[SUSP PATH] HKCU\[...]\Run : Spotify Web Helper ("C:\Users\Maël\AppData\Roaming\Spotify\Data\SpotifyWebHelper.exe") -> DELETED
[HJ] HKLM\[...]\System : ConsentPromptBehaviorAdmin (0) -> REPLACED (2)
[HJ] HKLM\[...]\System : EnableLUA (0) -> REPLACED (1)
[HJ] HKLM\[...]\NewStartPanel : {59031a47-3f72-44a7-89c5-5595fe6b30ee} (1) -> REPLACED (0)
[HJ] HKLM\[...]\NewStartPanel : {20D04FE0-3AEA-1069-A2D8-08002B30309D} (1) -> REPLACED (0)
¤¤¤ Fichiers / Dossiers particuliers: ¤¤¤
¤¤¤ Driver: [NON CHARGE] ¤¤¤
¤¤¤ Infection : Root.MBR ¤¤¤
¤¤¤ Fichier HOSTS: ¤¤¤
127.0.0.1 localhost
127.0.0.1 activate.adobe.com
¤¤¤ MBR Verif: ¤¤¤
+++++ PhysicalDrive0: WDC WD3200BEKT-60F3T1 +++++
--- User ---
[MBR] 408a562c14c040601116062909fedba0
[BSP] 71311cba74403f570223a666a72b7f04 : Windows Vista/7 MBR Code
Partition table:
0 - [ACTIVE] NTFS (0x07) [VISIBLE] Offset (sectors): 2048 | Size: 199 Mo
1 - [XXXXXX] NTFS (0x07) [VISIBLE] Offset (sectors): 409600 | Size: 305043 Mo
User = LL1 ... OK!
User != LL2 ... KO!
--- LL2 ---
[MBR] 88be900b81d4e27ef800065f2c8780ee
[BSP] 5d1a242686ce60ac1f61664168bb24fd : Windows XP MBR Code
Partition table:
0 - [XXXXXX] NTFS (0x17) [HIDDEN!] Offset (sectors): 409600 | Size: 59392 Mo
1 - [ACTIVE] NTFS (0x07) [VISIBLE] Offset (sectors): 122044416 | Size: 40000 Mo
2 - [XXXXXX] FAT32-LBA (0x1c) [HIDDEN!] Offset (sectors): 203964416 | Size: 600 Mo
3 - [XXXXXX] EXTEN-LBA (0x0f) [VISIBLE] Offset (sectors): 205193216 | Size: 200 Mo
Termine : << RKreport[2].txt >>
RKreport[1].txt ; RKreport[2].txt
kaiy
Messagepar chantal11 » Jeu 10 Mai 2012 19:50
OK pour le rapport RogueKiller.
Tu peux enchaîner avec Malwarebytes puis TDSSKiller.
Messagepar kaiy » Jeu 10 Mai 2012 20:26
Voilà les deux rapports, d'abord TDSS Killer :
http://pjjoint.malekal.com/files.php?id ... 13e13b7c13
kaiy
Messagepar kaiy » Ven 11 Mai 2012 19:19
Et voilà le rapport Malware Bytes, avec un peu de retard :
Malwarebytes Anti-Malware (Essai) 1.61.0.1400
www.malwarebytes.org
Version de la base de données: v2012.05.11.02
Windows 7 Service Pack 1 x64 NTFS
Internet Explorer 9.0.8112.16421
Maël :: PC-MAEL [administrateur]
Protection: Désactivé
11/05/2012 13:07:49
mbam-log-2012-05-11 (13-07-49).txt
Type d'examen: Examen complet
Options d'examen activées: Mémoire | Démarrage | Registre | Système de fichiers | Heuristique/Extra | Heuristique/Shuriken | PUP | PUM
Options d'examen désactivées: P2P
Elément(s) analysé(s): 484762
Temps écoulé: 1 heure(s), 35 minute(s), 36 seconde(s)
Processus mémoire détecté(s): 0
Module(s) mémoire détecté(s): 0
Clé(s) du Registre détectée(s): 0
Valeur(s) du Registre détectée(s): 0
Elément(s) de données du Registre détecté(s): 0
Dossier(s) détecté(s): 0
Fichier(s) détecté(s): 0
(fin)
kaiy
Messagepar chantal11 » Ven 11 Mai 2012 19:55
Merci pour les rapports.
Comment se comporte le sablier ?
Messagepar kaiy » Ven 11 Mai 2012 20:47
Toujours la même chose, il tourne alors que rien n'est démarré ...
Là je commence à désespérer :(
kaiy
Messagepar chantal11 » Ven 11 Mai 2012 21:28
Ce n'est donc pas d'origine virale, il y avait bien quelques intrus à nettoyer, mais ce n'était pas lié avec le comportement de ta souris.
As-tu testé avec une souris ?
Qu'est-ce que ça donne ?
Est-ce une souris filaire ?
Tester sur un autre port USB.
Une souris sans fil ?
Changer les piles.
Messagepar kaiy » Ven 11 Mai 2012 21:32
Je fais toutes les manips avec depuis le début ! C'est une souris filaire, j'ai changer les piles il y a une semaine, donc je ne vois pas pourquoi elles seraient déchargées.
De plus, j'ai essayé sans souris, mais en vain ... :(
kaiy
Messagepar chantal11 » Ven 11 Mai 2012 22:16
kaiy a écrit:De plus, j'ai essayé sans souris, mais en vain ...
Si la souris n'est pas connectée, tu as un sablier qui tourne quand même ?
Messagepar kaiy » Ven 11 Mai 2012 22:53
Oui ...
kaiy
PrécédenteSuivante
Utilisateurs parcourant ce forum: Majestic-12 [Bot] et 0 invités
