bluescreen
Performances, bugs, ...
bluescreen
Messagepar domflo » Jeu 27 Oct 2011 16:15
Bonjour, cela fait déja un bon moment que ce bug m'arrive.... les jeux sont bien installé, mais ne se lance pas. Au moment où ils se lancent, un écran noir apparait, et le rapport d'erreur m'indique bluescreen.... aprés recherche sur forums, et autres... je suis tombé sur celui ci qui proposé d'aider en envoyer l'analyse faites par le logiciel " Whocrashed " qui suit... pouvez vous m'aider car je pense que cela vient de ma carte graphique mais je n'en suis pas sur, vu ma maitrise en info ^^. Merci d'avance
Welcome to WhoCrashed HOME EDITION v 3.02
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. If will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit www.resplendence.com/support
Click here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which also allows analysis of crashdumps on remote drives and computers on the network and offers a range of additional features.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
computer name: FLORIAN-PC
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: AuthenticAMD AMD Phenom(tm) II X4 945 Processor AMD586, level: 16
RAM: 4294107136 total
VM: 2147352576, free: 1974276096
Crash Dump Analysis
On Thu 27/10/2011 13:47:41 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102711-15724-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x4A61CC)
Bugcheck code: 0x124 (0x0, 0xFFFFFA80053074F8, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
On Thu 27/10/2011 13:43:21 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102711-16208-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80053258F8, 0x0, 0x0)
On Thu 27/10/2011 13:37:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102711-15537-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800531F6D8, 0x0, 0x0)
On Wed 26/10/2011 11:22:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102611-20716-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80039D1588, 0x0, 0x0)
On Tue 25/10/2011 20:52:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102511-16224-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80052EA8F8, 0x0, 0x0)
On Tue 25/10/2011 20:48:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102511-15958-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80039D07D8, 0x0, 0x0)
On Tue 25/10/2011 14:59:26 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102511-24367-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80052D6038, 0x0, 0x0)
On Tue 25/10/2011 14:51:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102511-19609-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005329038, 0x0, 0x0)
On Wed 12/10/2011 12:52:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101211-18969-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800534C8F8, 0x0, 0x0)
On Wed 12/10/2011 12:48:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101211-19765-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80052E88F8, 0x0, 0x0)
On Mon 10/10/2011 09:21:31 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101011-20358-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80049688F8, 0x0, 0x0)
On Sun 09/10/2011 15:51:43 GMT your computer crashed
crash dump file: C:\Windows\Minidump\100911-16957-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800492D8F8, 0x0, 0x0)
On Sun 09/10/2011 15:46:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\100911-16567-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80049368F8, 0x0, 0x0)
On Sun 09/10/2011 15:43:18 GMT your computer crashed
crash dump file: C:\Windows\Minidump\100911-16208-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80049248F8, 0x0, 0x0)
On Sun 09/10/2011 15:39:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\100911-16099-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80052E58F8, 0x0, 0x0)
Conclusion
50 crash dumps have been found and analyzed. Only 15 are included in this report.
domflo
Re: bluescreen
Messagepar Ycor » Jeu 27 Oct 2011 18:40
Je te proposerai de faire un test de ta mémoire. Souvent ces problèmes de BSOS proviennent d'un module défectueux.
Tu peux utiliser memtest ou mieux encore memtest86 qui lui nécessite un CD bootable mais qui est plus perfo.
Re: bluescreen
Messagepar domflo » Ven 28 Oct 2011 16:03
Bonjour Ycor, merci pour ta réponse et ton aide .... j'ai telecharger et executer memtest et je voulais te demander comment s'en servir ... g lancer un test de mémoire sur tout " All unused RAM " et il n'as pas encore fini, cela fait au moins 2h qu'il test la mémoire ... c normal !!? en tout cas il indique 0 erreurs a 125% d'analyse !!! je voulais aussi te demander comment le lire ou interpreter ce qu'il vas me mettre .... merci d'avance .
domflo
Retourner vers Jeux vidéo
